G'day all,
I've done a search that came up pretty much zero before asking this, but don't grill me if I missed earlier topics about this: the phone app' is still pretty clunky on such things...
So, I've seen people have customer embroidered car covers, custom 'cut' covers to suit specific cars with unique additions to the shape(big aero wings etc) and covers that have special materials inside and out to help paint or keep dust off etc...
All I want is a neat fitting, quality cover that's made for the R32 GTR. Who's got what and where did you get it? Come at me with pics and names, please!!
https://www.sau.com.au/forums/topic/467970-car-covers/
I have one coming for xmas. It's this one:
http://www.supercheapauto.com.au/Product/CoverALL-Car-Cover-Gold-Protection-Tyvek-Suits-Large-Extra-Large-Vehicles/366564?menuFrom=1021713
I'll let you know how it fits my R33... Hopefully that will at least give you some idea.
I'll update this thread once I have it.
  • Like 1
https://www.sau.com.au/forums/topic/467970-car-covers/#findComment-7795146
i had one of these on my 32. its fit for a medium was a bit too tight for my liking as it pulled too hard over corners. but the soft lining collected and held dust. i took if off one day and i could see it leaving dust on my car, i dont care about dust on my car but not on all the lining rubbing on the car.
  • Like 3
https://www.sau.com.au/forums/topic/467970-car-covers/#findComment-7795214
  • 3 weeks later...
How did this fit?  I want to get the same for my R33
https://www.sau.com.au/forums/topic/467970-car-covers/#findComment-7799628
I bought an indoor car cover from http://www.coverworld.com.au/car-covers.html
wasnt custom, just XXL sedan (could have gone one size smaller for the gloria). Its good quality and I havent noticed any marks on the car. it can get dirty underneath the cover when not being used or put on a dirty car. I just give it a vacuum.
I've got an older AutoTechnika outdoor car cover and dont recommend it. I found it rough, water seeped through and unless tied down PROPERLY would get blown off in the wind.
  • Like 1
https://www.sau.com.au/forums/topic/467970-car-covers/#findComment-7800029
Hello. A quick update following Christmas.
Even though i specifically gave a part number, somehow I ended up with a different car cover. I think mine is a Silver or one step down on the product rung.
I have put it over the car and it is a very close fit on the rear end. The wing means that you only have about one centimeter of extra fabric. It's very very close to not fitting at the rear.
I put it on in the dark so pictures will follow...
https://www.sau.com.au/forums/topic/467970-car-covers/#findComment-7801161
I use two, the supercheap red fleecy/soft cover then a hailproof cover over that.  The fleecy is for to protect the paint, the hailproof - cos my car is in a carport - is for the odd rain drop and possible hailstones.  But I am pretty sure it won't stop cricketball sized hail, just the smaller golfball or lower I think.
I have a shed, but it is full, so the car had to sit in the carport.
Got the hailproof outer on ebay.  And stay away from custom covers, cos you will be replacing them every 2-5 years anyway.
https://www.sau.com.au/forums/topic/467970-car-covers/#findComment-7802030
  • 3 weeks later...
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
