Lost boost after exhaust Mod.
Hi guys,
something Wierd happened to my r34 GTT like the title says I've lost boost after installing a just jap bell mouth dump to cat.
Nowmy previous setup was just a blitz cat back and I saw 9psi.
Now ive installed the turbo back jjr bell mouth and gutted my cat I'm only getting 7psi.
I would of thought freeing up the exhaust would give me more boost or the same.
Can someone tell me where I've gone wrong ? Is it cause I gutted the cat?
any help would b much appreciated
thanks.
https://www.sau.com.au/forums/topic/467982-lost-boost-after-exhaust-mod/
56 minutes ago, Jonic said:
Have you tried resetting the ECU, by taking your battery out and let it reset ?
that's not going to do much, all you're resetting are the long term fuel trims
CAr still pulls hard, it's just that I've lost a couple of psi.
Same boost gauge nothing's changed besides the dump to cat pipe. Ohh and gutting the cat.
If I flaw it in 4th it hits 8psi but Sits on 7psi for the most part.
I always thought freeing up the exhaust would increase boost not decrease it.
Anyways I'll look else where but any ideas are very much welcome!!
cheers
Ash
As I said before it will increase flow and therefore may increase power. Pity you didn't do an 80 to 120 time before so you could measure it after and see if your car is actually going faster.
Get a simple boost T or something and see if you can raise your boost again - it should make more power at the same boost level or you could go to 10 or so.
I would expect reducing restriction post turbo should help increase boost not decrease it.
As above, I know here have been some issues with JJR Dumps in the past so it could be that. I wouldn't stress too much about it. As above, car is probably just as fast/faster and you can easily bump it back up to 9psi if you want to with a manual boost controller
Did this no difference. Also Had the boys in blue make a showing. f*k wit neighbors.
Looking at the standard dump pipe the wares gate opens and the gasses hit the cast iron almost straight away.  (Hope yous know wat I mean)
with the bell mouth the gasses flow more with the flow coming from the exh wheel.
Me thinking old dump was restrictive giving 9psi now more flow I'm seeing 7psi
but this all contradicts what I originally thought.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
