SKYLINE WON'T drive normally
So after thrashing it down the road, my car went into a LIMP mode, now when I drive, it won't go over 2000rpm, even when parked I can't rev it pass 2000, it's like hitting a rev Limiter. So I suspected the AFM, spark plugs and Coils so, I cleaned the AFM (sprayed it down) and replace all my coils and spark plugs. Car starts up great but the problem is still there, what could it be?
I have reset my ECU already.
Before the limp mode starts, the car will drive fine till about down 3mins after it will just LIMP MODE the whole way, once I start my car again it will be normal for abit and then again LIMP
My Skyline is R34 Triptronic.
My engine light has always been on before this occur so I can't tell if another problem popped up so I have to check on that.
I think also my A/T flashes before I start my car
IMG_2500.MOV
https://www.sau.com.au/forums/topic/467992-skyline-wont-drive-normally/
If your Mass Airflow sensor is broken the car won't exceed 2000rpm
This thing is when I start the car it will drive normal and goes over 2000rpm but after about 3 mins or so it will just start to choke and chug and can't even drive over 40kms :(
It was on for a reason - there's something wrong. **Sigh**
So God only knows what might have broken to cause your current situation. (but I'll back the AFM as the chief culprit)
  • Like 1
  • 4 weeks later...
Car runs fine now and I didn't do anything really, just reset the code and I can finally drive it pass 2000rpm. Problem now is when I'm driving, at a red light my idle drops and sometimes the car dies, but starts right back up no problem. Any clues because my mechanics are clueless. The cel code was A/T and ABS fault but that has nothing to do with my current problem zz
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
