Just looking to see some feedback and opinions on changing from a stock intake to a forward facing style.
It seems like a fairly pricey thing to change and would take some labour and adjustments under the hood.
It seems very logical to run a forward facing plenum for many reasons. I would like to know what effect you felt it had on your car.
https://www.sau.com.au/forums/topic/467997-rb25det-forward-facing-plenum/
Look 100x better, 100000x easier to change/upgrade injectors, easier to change spark plugs... little bit of stuffing around to convert but nothing major. Much shorter inlet path.
Would be interesting to see if someone has done a back to back comparison on a near stock motor with no changes other then the intake... When I did it I changed injectors and turbo at the same time so cant really compare
I asked for back to back results on the same tune a few years ago. From memory someone did post results and they were in line with what everyone else says. The theory and results behind the plenum is almost the same as na, which is surprising.
Yeah they look good and you can clean up all wiring and coolant and fuel lines to fit below it. But it's still around $400 for a useless thing.
Have around $400 spare and want something to do? Go for it
I have talked myself out of non standard RB25 manifolds and plenum chambers so many times it isn't funny .
Just yesterday I was looking at a pretty blue Freddy going onto a GTS25T and asked again the shop owner does this cost torque and drivability right where cars are driven most of the time .  Quick answer , yep more top end but costs down low .
It is also very obvious that things like the thermostats housing and oil filter are considerably harder to get at . No crossover pipe but that's not real hard to remove once you've done it once or twice .
I think the reality is that the J pipe or whatever is the way to go or if being real stealthy you're stuck with return flow type intercoolers .
The factory alternatives are the RB26 setup or the Y pipe and plenum like some R34 RB20/25 DEs use .
I've got one on my motor,why? For bonnet clearance when my 25 was in my 180, now I still have it on my 32 as bonnet clearance with an rb30 and because top feed standard hight injectors.
More top end? Barly noticeable at 300kw, however there was a noticeable loss of low-end/midrange power on the rb25 can't comment on the difference with the 30 thou
  • Like 2
i have back to backs with 320rwkw greddy and plazmaman vs std and in both cases there was very little difference and there was zero difference between std throttle and q45 on the greddy at 350rwkw.
That said the extra accessibility was worth it on both cars as they see lots of track work.
  • Like 2
Groundhog day?
I've never regretted mine, but it was part payment for some wheels. Car has always driven fine
  • Like 1
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
