Help with buying a V35
Hey Guys! So like many i am new to these cars. I have read many of threads on the forums to inform me of the V35 Skylines. I have currently found a 2003 V35 with 83,000kms for $10,000. The car unfortunately has no paperwork. It has a service history of the last 20,000kms the owner has owned the car. Would you guys recommend looking at the car or ruling it out completely due to having no books or service history.
Edited by james1999
https://www.sau.com.au/forums/topic/468017-help-with-buying-a-v35/
My car was i ported with 78,000km just over 2 years ago. I purchased directly from an importer who was able to provide me with the de-registration papers to verify the mileage. This was important,  beacuse in Japan they register the car every two years and the km are recorded each time, so you can tell if the mileage at the time of deregistration is consistant with the last time it was registered. I was lucky as well that a workmate had a contact  in the import industry, who was based in Japan, who verified the car had never been in an accident.
Unfortunately  log books are very rare on imports and I dont even have one on mine. I had a sticker on the intake advising the last service was done at 77k kms. I didnt believe this sticker and serviced the engine, transmission and diff. Unfortunately I was wrong, as all the drained fluids were brand new, and I could have saved myself several hundred dollars on servicing costs. It could be that I purchased one of the only honest cars from Japan...
But to be fair, in the first 12 months, I had to replace the air con and power  steering belts, front  and rear brake rotors and pads. In the last 12 months I have replaced the diff bush, lower control arm bushes and swaybar end links. The car came with Tein coilovers- the front split a seal and cost me 800 to fix around 18 months ago. My rears just had the same thing happen, and I am about to send them to Fulcrum in QLDto be repaired. I still need ro replace the radial bushes, which will cost nearly $600 (as you need a 4 wheel alignment as well).
My point is that you are buying a relatively old car, and it is at the age where things start to fail. If the previous owner has fixed a lot of these issues, then go for it. If not, get an independant inspection done. Other common issues are cam sensor failure, faulty airbag codes, worn wheel bearings and power window  modules. If the mileage seems to good to be true, check for worn floor mats, steering wheels, kick plated and door handles etc as telltail signs.
Truth  be told, every time you buy an import, you are taking a punt. They are fantastic cars,  very underrated and very reliable. I have pwned other imports, including an R33 and R34 turbo skyline, and V35's are in a league of their own. My advice is to take your time, do your research, and make sure you buy the right car- dont just shop for price. Hope this helps.
  • Like 2
Thanks for that! I agree. i will definitely view a number of different cars and wait until something good comes up. Cheers mate!
If you are concerned about its 'pre import' history, order a report from one of the companies that can pull the auction records from Japan, that way you can get an idea if it has had the odo wound back, was a repaired write of, etc.  eg http://www.japaneseodometercheck.com/
If you are still interested, get it checked by a mechanic familiar with these cars or 350Zs, tell them it has no service log books and you just want it checked accordingly (compression test, etc).
Cheers! I will definitely follow these steps!
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
