I asked for a Midnight Purple Skyline from an importer in Qld they went looking and found this in Japan . I also asked for something rare and they hit the jackpot for me anyway
I was pretty happy back then still stoked to this day
On 18/12/2016 at 7:22 AM, mercyseat said:
Welcome, I own a 1997 SII 40th Anniversary midnight purple coupe too!
Damn that looks super clean!
Was a fresh import earlier this year. Only 96,000kms and 100% stock original.
Went like a rocket but we had a little front prang earlier this year so it's being fixed.
Definitely fun to drive even as a stocky. Good solid engines.
I've got a silver 1997 SII 40th also but I have to part that to fix my other one unfortunately.
Your car looks super clean too!
  • 3 weeks later...
I believe that the gtr wing was optional at purchase as I didn't buy brand new, choice wasn't mine .
It has the 40 th badges on the outside , seats with 40th badges , powered fold in mirrors , sunroof , hicas , passenger air bag and drivers air bag , mine is a GTS-T not a Gtr I'm not fluent on the GTR registry .
brake light is in the rear wing also , seatbelt retractor , climate control , rear strut in boot not sure on that
Just checked mine on GTR Registry and found below:
ECR33-133971
GTS25t Type M 40th Anniv (Series 2.5)    1997-11
2 Door Coupe; RB25DET; 2WD HICAS; 4 Speed Automatic; (14A) Super Fine Hard Coat; (15A) Rear Wiper; (16Z) Trunk Lid Trim + Sports Shift Knob (Automatic) + Type M 40th Anniversary; (17C) Remote Entry; (18M) Viscous LSD + ABS + 40th Anniversary, 2 door
Def have rear boot strut bar, 40th Anniversary interiors, original Japanese radio/cassette player.
The second 40th Anniversary KR4 Sonic Silver model I have up for sale has same specs as above but build date 1997-12.
ECR33-134288
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
