R34 GTR ECM/ECCS Relay power source
Hi Everyone,
For some unknown reason my ECM/Coil relay is not getting its supply power, as such the ECU is also getting no power on pints 49/59.  I have spent days trying to locate the reason for this and need some assistance in confirming a few things regarding R34 GTR wiring.
First thing of course was that I've checked all the fuses.  Initially the top row-left use (10A Electrical components fuse) was blown.  I replaced it, and it has not blown again since.
The ignition circuit that switches ground to one side of the ECCS relay is functional.
I have tried hot-wiring power to the ECCS relay by connecting pin 3 to +12V, and the relay operates as it should and the ECU powers on properly. So there's my fix should I give up on fixing this issue properly.
The next thing I started to bypass was the aftermarket black widow alarm system, as I suspected the immobiliser relay may have gone open circuit (although it does click).  Bypassing most of these circuits, (and confirming the immobiliser relay was actually switching) was easy to confirm.  Still no go.
Yes I run a Haltech ECU, which in theory ignores the factory immobiliser.  But the immobiliser is still in the car, and there might be a fault with it.
Does the factory immobiliser isolate the ECM relay?
Other than at the fuse box, is there another place in the car that I can check the power to the ECM relay?
Other than the alarm install, the loom is relatively unmolested.
Any idea's or suggestions appreciated.
Cheers,
Ian
https://www.sau.com.au/forums/topic/468031-r34-gtr-ecmeccs-relay-power-source/
Fixed it, and it was more simple than I had thought.
ECCS relay power comes from the fuse box at the back of the car, being constant/unswitched power.
Who knows the odds of blowing an IGN Electrical components fuse and a rear constant power fuse at the same time.  Possibly something to do with my upgraded ignition/haltech or all of the above.
Either way who cares, so long as I can drive the car again!
  • Like 1
  • 1 year later...
Have the same problem with my friends R34 and at the same time coolant all leaked... strange ... will check the fuses at the back first.
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
