Well as alot of you know i sold my M35 about 6 weeks ago (old photo to show my last m35) . Being a regretful sale i have recently purchased another M35 Stagea i pick up Saturday i got for a great price as it needs a little work. Comes with
- Full Nismo Bodykit
- Nismo Wing
- Rsr Coilovers
- Double Din Headunit
- Hypergear SS1 Highflow
- Custom Intercooler set up
- 18 Inch Wheels
- Nismo Cat Back
- Hicas (vlsd)
- Rain Guards
- Intergrated Audio Setup
ISSUES
- BCM error code (possible replacement needed)
- Front Bar needs repairing
- Plastic Trims Need Reinstalling (undertray & inner guards)
20161204_173521.thumb.jpeg.e14128da096be20161204_173527.thumb.jpeg.817f504791e4a20161204_173530.thumb.jpeg.7b6c5285d604c20161204_173534.thumb.jpeg.8681dfaccf92220161204_173541.thumb.jpeg.5ff7478f388afFB_IMG_1479443280024.jpeg.de53b8d6d5d49b
  • Like 4
https://www.sau.com.au/forums/topic/468038-joshs-nm35-version-2/
Yeah man for sure. When ever i was board i would go pull the stagea apart and fix bits i want happy with. Picked this up for 3k (kit, exhaust & coilovers worth that alone) so will be a good little project to get her back to her glory.
That integrated audio is crazy! I've never seen the speakers placed like that before. Was it done in Australia or did it come out like that?
The owner advised the the stereo was done in Japan prior to importing to Australia. Im picking the car up tomorrow night so will be able to go over it in more detail soon. Exciting times
Welcome back. What plans have you got for this one?
1st thing is to get her running (currently not due to bcm). Then not sure from there. No where near what i did to the other one. I do like this design thoughFB_IMG_1480851040550.thumb.jpeg.1236cb80
So today i got some time to clean up the stagea can check over.
- battery compartment cleaned and bung removed
- new battery terminals
- new battery
- stereo system power cable connected and tested (sounds amazing) roof and rear screen wiring needs to be checked
- old redundant alarm/wiring removed
- fluid levels checked (radiator missing overflow bottle) and needing to be bled
- area around wiper arms cleaned up
- bcm casing appears to be broken and with it throwing a bcm error code i can hear it the internal relay clicking not allowing car to start. (Another bcm sourced)
- a photo for the size of the front tweeters. Never seen one this big.
20161209_162230.jpeg20161209_164331.jpeg20161209_165718.jpeg20161209_175023.jpeg20161209_175408.jpeg20161209_184622.jpeg20161209_181527.jpeg20161209_181537.jpeg20161209_192646.jpeg20161209_193423.jpeg20161209_192653.jpeg
  • Like 1
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
