Well as alot of you know i sold my M35 about 6 weeks ago (old photo to show my last m35) . Being a regretful sale i have recently purchased another M35 Stagea i pick up Saturday i got for a great price as it needs a little work. Comes with
- Full Nismo Bodykit
- Nismo Wing
- Rsr Coilovers
- Double Din Headunit
- Hypergear SS1 Highflow
- Custom Intercooler set up
- 18 Inch Wheels
- Nismo Cat Back
- Hicas (vlsd)
- Rain Guards
- Intergrated Audio Setup
ISSUES
- BCM error code (possible replacement needed)
- Front Bar needs repairing
- Plastic Trims Need Reinstalling (undertray & inner guards)
20161204_173521.thumb.jpeg.e14128da096be20161204_173527.thumb.jpeg.817f504791e4a20161204_173530.thumb.jpeg.7b6c5285d604c20161204_173534.thumb.jpeg.8681dfaccf92220161204_173541.thumb.jpeg.5ff7478f388afFB_IMG_1479443280024.jpeg.de53b8d6d5d49b
  • Like 4
https://www.sau.com.au/forums/topic/468038-joshs-nm35-version-2/
Yeah man for sure. When ever i was board i would go pull the stagea apart and fix bits i want happy with. Picked this up for 3k (kit, exhaust & coilovers worth that alone) so will be a good little project to get her back to her glory.
  On 07/12/2016 at 12:50 AM, Dunc said:
That integrated audio is crazy! I've never seen the speakers placed like that before. Was it done in Australia or did it come out like that?
The owner advised the the stereo was done in Japan prior to importing to Australia. Im picking the car up tomorrow night so will be able to go over it in more detail soon. Exciting times
  On 07/12/2016 at 9:06 AM, datmoo said:
Welcome back. What plans have you got for this one?
1st thing is to get her running (currently not due to bcm). Then not sure from there. No where near what i did to the other one. I do like this design thoughFB_IMG_1480851040550.thumb.jpeg.1236cb80
  On 07/12/2016 at 11:16 AM, West said:
Get it running man ..... i now have a spare Scotty 3" intake that you can have for dirt cheap, you know how i roll! :banana:
Now you are talking. Picking it up tomorrow arvo. More photos to follow
So today i got some time to clean up the stagea can check over.
- battery compartment cleaned and bung removed
- new battery terminals
- new battery
- stereo system power cable connected and tested (sounds amazing) roof and rear screen wiring needs to be checked
- old redundant alarm/wiring removed
- fluid levels checked (radiator missing overflow bottle) and needing to be bled
- area around wiper arms cleaned up
- bcm casing appears to be broken and with it throwing a bcm error code i can hear it the internal relay clicking not allowing car to start. (Another bcm sourced)
- a photo for the size of the front tweeters. Never seen one this big.
20161209_162230.jpeg20161209_164331.jpeg20161209_165718.jpeg20161209_175023.jpeg20161209_175408.jpeg20161209_184622.jpeg20161209_181527.jpeg20161209_181537.jpeg20161209_192646.jpeg20161209_193423.jpeg20161209_192653.jpeg
  • Like 1
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
