I wonder if the PNM35/G35x trans would plug in to your loom. Might be a worthy swap as it has nicer changes and no external pump to worry about.
I will definitely look into that option. Need to remove the box to replace the output shaft speed sensor as its located in the spacer between the transfer case and valve body. (Need to remove both transfer case and spacer to get to it)20161218_104637.thumb.jpeg.73984d24d0201
Installed the front pipe with new bolts and gasket as well as polished up the Nismo catback. Dash removed and wiring checked and pins reset ready for the parts arriving on Wednesday from Jason. Also removed the outsidereo that was on the Nismo rear bar for a cleaner look. 20161219_191824.thumb.jpeg.7182ac79d9ec2FB_IMG_1482141176859.thumb.jpeg.62cf1cba20161219_191837.thumb.jpeg.891d587d2b9c020161219_193856.thumb.jpeg.5a46bc50db12720161219_194255.thumb.jpeg.faf7e8f87d36f20161219_200124.thumb.jpeg.eff16636d5ac620161219_210909.thumb.jpeg.28cae71eee0e2
  • Like 2
With new carpet, washer bottle etc arriving yesterday from Victoria the stagea is almost back together. Still have some headunit wiring to sort out along with reinstalling the amps. Have a locksmith booked in for the 30th for reprogramming and diagnosis. 20161221_104057.thumb.jpeg.207e11d9f160d20161222_155504.thumb.jpeg.4e3dce908888d20161222_155526.thumb.jpeg.ea2141c78128f20161222_155537.thumb.jpeg.b6301eefa578a20161222_155549.thumb.jpeg.63cebea29bed820161222_155614.thumb.jpeg.51442d847acd4
  • Like 1
Todays job was to reinstall the weather shields. Ive noticed they have been sprayed with what i think is that tail light tinting spray. I will have to sand them back and reapply as the coverage is poor. When i ripped the rainguards off they had the old grey tape still on with a few sikaflex'd on with white sika flex (more of a sealing agent than a adhesive) and the other few had white double sided tape so both were very noticable. So i have removed 95% and taken back to the bare plastic. I then used a black adhesive sikaflex that will hold them better and hide the adhesive more. Just have to remove the tape after 3 hrs and wipe away any excess sika with grease & wax remover. 20161224_110116.thumb.jpeg.20062f0d478cc20161224_110121.thumb.jpeg.ee765768f29ba20161224_112406.thumb.jpeg.0e67e28ec234620161224_110543.thumb.jpeg.2bb3119a9c07f20161224_112345.thumb.jpeg.812221d37fca220161224_112358.thumb.jpeg.5836059932196
  • Like 1
Got a bit of time today so worked on the amp mount location. I received a under boot tray a few days ago so put it to good use and mounted the amps where i had my last one. I just need to wire it all up and install 4 pcu fans to circulate air around the amps. 20161224_201021.thumb.jpeg.f09e5b5d0b23820161224_201530.thumb.jpeg.9a16f050fbd5920161225_173005.thumb.jpeg.332a776a4f3bf20161225_173955.thumb.jpeg.15a6f2c890de120161225_174551.thumb.jpeg.4a0dea020f39e
  • Like 2
Been a big development with the stagea over the last 24hrs. She now started. I have read up that because the car never shown a engine light there was a possible earthing issue so i started checking all wiring in the engine bay. Found a black plug next to the battery that, to the naked eye looked connected, when pushed down it clicked and gave me back the engine light. I still had no starter signal when key was turned but i have fuel pump and fuel through the injectors. So i hooked up a direct 12v feed to a push button and now car starts. I still have to find why there is no starter signal but for now she starts and i can move her around and have all the other items addressed. 20170103_200349.thumb.jpeg.9b0b7b27a09b720170103_172626.thumb.jpeg.42ee20677a04920170102_113758.thumb.jpeg.a80cb968733ac
  • Like 7
Have you had a good look at the IPDM ?, could have moisture damage
No was replaced. I have decided to strip the car. Was unable to decipher the issue within budget.
Stripping the M35 stagea - Brisbane
RSR coil overs (4wd) (non base height adjustable) - $700.00
Nismo Fibreglass Bodykit some cracking (front, side, rear ) - $1000.00
Nismo Exhaust (cat back) - $1100.00
Car audio (pioneer double din headunit, pioneer 2 & 4 channel amps, 4 x 6.5inch pioneer speakers with tweeters, wiring kit, roof mounter screen with control boxes- $800.00
18 inch wheels (tires 80%) - $500.00
Window Motors (front passenger & both rears)- $300 ($100 each)
Black interior (no boot floor, boot side shelf panels, rear door cards) - $400.00
Vlsd - $250.00
1 x bcm $50.00
2 x stock ecu - $75.00 each
Intercooler with piping.- $150.00
Airbox - $40.00
Doors - $200.00 ($50 each)
Dash Pocket - $100.00
Rear Aero Bar - $150.00
Rear Door & Glass - $150.00
Steering wheel (with airbag) - $150.00
Starter motor - $100.00
Happy to post at buyers expense except for the engine.
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
