R33gtst
 Hey guys I'm Daniel I'm a new owner of a 1995 r33gtst just got it last week I'm interested in getting to know more about these cars I owned one a few years ago it was a r32 but was on my ps so couldn't get to enjoy driving it so now I can roll with the big boys lol after easy mods parts and anything that may intrest me so far I'm loving the skyline goes very good only things done is front mount 3inch all the way back an two stage boost set on 10psi is there any other easy cheaps mods? And thank you for al your replys in advance
https://www.sau.com.au/forums/topic/468046-r33gtst/
To get more power at this stage you'd have to go bigger turbo, ecu, and other supporting mods which aren't exactly cheap, easy mods for power.
You could do small things such as pod filter with heat shield, metal intake pipe mod (for better induction noise and turbo flutter), or install a catch can. All pretty easy mods which don't cost much.
https://www.sau.com.au/forums/topic/468046-r33gtst/#findComment-7796633
Hey guys I have tried posting in other places an al I get is error something went wrong am I doing something wrong? I need help with my car it's a r33gtst series 1.5t type m and I'm having starting issue hot or cold doesn't matter car cranks fine but takes a wile to fire up if I give it gas it fires up a lot Easier can anyone help it's got me stuffed? I have change fuel pump new plugs new coils cleans maf mods are front mount 3inch turbo back. Could it be fpr? it drives and runs beautiful just the starting issue
https://www.sau.com.au/forums/topic/468046-r33gtst/#findComment-7797095
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
