Hello
I'm Shedley, and I live in Belgium. I'm reading here for i while but i thought it wasa good moment to start my own topic!
Two years ago I bought a R34 GTT from japan, with some Nismo bits and a 3" ganador catback. It had 105k km on the clock. It took a lot of time to fix the papers and registration, but now everything is OK.
Recently I started my own business, so i thought it might be a good idea to make my own gtt the promo car!
The car will do a few trackdays a year and will be set-up for that.
To be continued....
IMG_1481234575.373779.thumb.jpg.040c5738IMG_1481234587.147884.jpg.f76eece0968f34IMG_1481234596.315242.jpg.81307f19fa9d2b
  • Like 2
https://www.sau.com.au/forums/topic/468059-r34-gt-t-track-minded-promo-car/
First update!
One and a half year ago, before i knew what i would do with the car, i bought myself a new set of HKS Hipermax IV coilovers.
It has 7kg springs in the front and 5kg in the rear. I know this will be way to soft for track work, so for that reason i've took the coilovers apart and we'll put them on the testbench. We will look to the damping and see what has to change and we will also calculate new stiffer springs.
IMG_1481234995.817593.thumb.jpg.f681ac3d
  • Like 2
UPDATE!
Today, we've put the hks's on the test bench. Overall, they are good street dampers, the adjustment dail does it's job of changing the characteristics of the damper. But it almost doesn't adjust the bump, wich is crucial. So we will now dissensamble the dampers, and look if we can change something...
From my calculations, i have concluded that if i put the front springs of 7 kg/mm due to the curent power level, which should work well on track i think.
In the front i would obtain for something around 15 kg/mm.
We hope that will work, and that we could adjust the valving in a good way.
I also received another update, some Yokohama AD08 rubber, 265 square setup
Desided to sell the HKS dampers, and buy something new, 2 way adjustable.
KW competition 2 way is something what interests me but we'll see what we can get our hands on.
For now i will start with my nismo s tunes, because they have a much firmer bump damping as those hks's, rebound dampins is also hks damping X2
UPDATE!!
Some new parts have arrived [emoji108][emoji851]
Pictures will follow
What's in the box?
- adjustable tension arms
- front adjustable camber arms
- front LCA's with roll center correction and adjustable track
- rear LCA's with roll center correction and adjustable track
- rear adjustable camber arms
- traction rods
- toe rods
- hicas delete
- uniball bearings for the rear knuckle's
- rear subframe reinforcement plates
- subframe alu riser bushes
- alu differential bushes
- hell stainless brake lines
... more to come ;) [emoji847]
Update!
As i've said, there arrived a lot of parts. All off the suspension arms are being painted in a different color so pictures of those will follow, but for now, here are some pictures.
First part: Mishimoto racing thermostat (68deg.). As a nismo item isn't easy to buy up here, i ordered myself a mishimoto thermostat for my NEO engine as the original has a high opening temperature from 82deg, which isn't as good for the cylinder head heat transfer on track.
Then up to the brake system: I've go for some Performance Fiction Brake pads to suit the original calipers, we'll see how this works. Iv'e chosen for compound 11, which i'll think will work pretty well for trackdays ..., I Hope ... :3_grin:
This wil be combined with the hell brake lines and Motul RBF660 brake fluid
Look to the packaging of those brake pads :banana:
Another small thing, as i will replace the clutch soon, i ordered also a new, bronze shifter bush
For the clutch himself, i've done a bargain at one off my suppliers who had a this clutch in overstock, so for this reason i bought this Exedy Hyper Carbon-D Twin clutch, which should be able to hold 600 angry horses. More then enough for my goal, as i have a TD06-20g waiting on the workbench to be mounted later on, combined with a link G4+ (as i'm dealer of it:blink:), probably mounted on the stock manifold with an EXT. Gate. But i'm not sure the stock manifold will be a good choice, aiming for 275rwkw.
Suspension wise, there also arrived some parts:
SPL rear knuckle uniball bushes, GKtech subframe riser bushes and some alu differential bushes
My wheels also arrived, yes i know, another Volk Reps ... But as i am dealer of Japan Racing, and they're giving me a nice discount as those wheels are for my promo car, I was almost forced to buy these wheels :banana::devil: They are 18x9,5 ET38 on the four corners. I've done a testfit, and it will be a very tight fit ... buuuuttt ... good news, i've contacted viva garage becease i'm intrested in the rear overfenders and front Z-tune style fenders, so we'll see if they want to ship to Belgium :17_heart_eyes:
More to come .... Exited!:2_grimacing:
  • Like 1
Tires are mounted on the wheels, they look brutal [emoji13]
IMG_1483099133.851237.thumb.jpg.6ab22c35
Testfitted them on the car, the rear fits well, they are pretty even with the guards but this isn't a big isue as there will be mounted overfenders in the near future ...
The front is another story, they hit the arm who connects the knuckle to the top wishbone, so i think i'll need a spare there ...
To be continued ...
Update!!
Last week i took some time to work on the car :224_monkey:
Subframe rubbers where crusty :2_grimacing: Good they will be replaced !
For the rest of the time we took some time to disassemble the rear axle, so we could inspect everything and sandblast the subframe before welding in the reinforcements.
As the diff is out of the car, i took my shot to look whats inside of it .... Aaaahhhhh, stock helical LSD .... :4_joy:
Update!
Finally, after 7 hours of sandblasting, the subframe is ready to weld in the reinforcements. It was a hell of a job, with sometimes a failure of the machine :banana:
896CF389-D486-4A82-891D-E5071C5565BA_zps
So after this i welded in the reinforcements en took the subframe to the powercoating, normally i would have it back this evening, so then we could mount the bushings, assembly the rear suspension arms, en put the axle back under the car.
2C5B2D40-983A-4D12-87AD-74200B95637B_zps
B64A8079-86E7-4743-986A-0A15A6256648_zps
EF0D368A-0593-456A-B117-BF51D02E0F78_zps
22A63DBF-4FBE-4F61-9184-CEBE3B922E82_zps
DF5AC1AE-ABCA-4243-8286-E67A25D9CF34_zps
9B943BDA-5F8A-498C-AC90-DE6F6DCC7185_zps
378F4309-FB08-447A-A99D-80AF72653C14_zps
11B3CADD-6E77-468D-BCEE-715865123F7A_zps
  • Like 2
    • Splitfire Nissan RB Twin Cam Street Series Splitfire Coils. Basically brand new less than 10kms use. Only selling as ive upgraded to the IGN-35A coils $400 price pretty firm
    • We have 2x Swifts and my plans for a Swift, unfortunately, do not extend to an intake and an exhaust. I've been having dirty thoughts about a 2.5L Suzi V6, AWD gearbag out of a suitable donor, rear floorpan graft to take the rear cradle from same, and either trumpets of evil or a small supercharger. If I'm going to make noise in a Swift, I want it to be anti-social, evil handling and rough. Probably need to be fully stripped inside, matt black paint, plastic windows, 7" wide wheels, big brakes, silly suspension, etc etc etc. I have no idea if any of the proposed driveline components could take the pain. But it would be a hoot finding out.
    • Really, anyone modifying a car isn't being financially smart. We're doing it for the things we love. And honestly, a high revving, light, NA car is actually pretty darn fun. I used to have a Swift Sport, and I miss that thing as a daily, and yes, doing something like some intake and exhaust stuff would have made minimal gains, but would have bought an even bigger smile
    • We are taking pricing back to 2022! The skid pan is nearly double the size of avalon so much better for longer battle runs as seen here > https://www.youtube.com/watch?v=ANxdRf3Do2s When: Saturday 14th June 2025 Where: Winton Skid Pan (Winton Motor Raceway) Price: $145 for SAU VIC Members            $199 for non Members Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and it is reccommended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs on the enty link. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Accommodation:  In an effort to try new things and support other country towns we thought a new location for accommodation was worth trying and Euroa was great last time plus its 30 minutes closer to Melbourne. Saturday night we will book a spot at the pub for a couple of quiet drinks.......   Book your accommodation ASAP before it sells out, there are also other options in town if you want to stay elsewhere and join us for dinner Saturday night.   https://euroacaravanpark.com.au/ Address: 73-103 Kirkland Ave, Euroa VIC 3666 Phone: (03) 5795 2160 Entry link with Full Supp Regs to read: https://www.sauvic.com.au/entry/deca/20250614 Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1. Josh M 2. Anna 3. Luke  4. Katie 5. Martin 6. Tony 7. Alix 8.  9.  10.  11.  12.  13.  14.  15. 16.  17.  18. 19. 20. 21. 22. 23. 24. 25. 26. Reserve List 1. 2.
