Haha f**k how did you manage that? I understand on RB30 ones which have cooked old crusty oil in the keyway preventing the 10mm hex key getting in there.
1 hour ago, niZmO_Man said:
Surprised you didn't put a V8 in already :P
2JZ-GTE VVT-i with a GTX4088R, twin gates, twin scroll would be my pick :)
But... I'm poor.
  • Like 1
Managed to get out the remaining head bolts by cleaning the head, removing all debris/oil/shit then hammering in a hex slightly the wrong size in.
Next surprise were the cylinders, dirtier than a Kings Cross hooker, surprisingly the cylinder bores were still good! Used a bit of elbow grease and cleaned them up and now sits ontop a thin layer of oil.
Head will be sent off next week the Hanoi fit new seals, retainers, springs, cams and possibly adjustment to shims  (if required).
  • Like 4
head being sent off, getting a few basic things done:
  • light skim for straightness
  • a good clean because it's dirtier than a kings cross hooker
  • installation of stiffer valve springs, titanium retainers
  • installation of cams and shims check/replaced to suit
Also are R33 and R34 RB25DET balancers the same? well I know the R34 under drives the AC compared to the R33 one.. but are the ribs the same?
I have a R34 NEO going in but with R33 PS, AC.. so thought it would be best to use the R33 balancer for obvious reasons. Searching the site (on Google) didn't reveal any answers.
So used the gates website and I can see that both use the same ribs.. however length is different due to the drive:
4 Rib A/C Belt:
R34 RB25DET NEO is 915mm
R33 RB25DET S1/2 is 915mm
4 Rib Water Pump/Alternator Belt:
R34 RB25DET NEO is 890mm
R33 RB25DET S1/2 is  855mm
Turns out the R34 uses a 4 Rib Power Steering Belt and the R33 uses a 3 Rib.
Guess I've answered my own questions haha.
33 minutes ago, ActionDan said:
Still has pads? Weak source. They should be removed for 1000hp builds... Do it.
No... I'm not a moron.
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
