37 minutes ago, Dose Pipe Sutututu said:
That's how the NBN is being rolled out lol
lol no, the NBN is being rolled out equivalent to you just saying f**k it and using the cracked o-rings
48 minutes ago, Dose Pipe Sutututu said:
So close yet so far, typical NBNish delivery lol.. Over budget and project schedule blown out of the water.
This is EVERY Government funded project
  • Like 1
  • Haha 2
1 hour ago, iruvyouskyrine said:
Those bolts go at the very back of the head on either side. Do you even RB bro?
No :(
I SR20 more lol...
where exactly????
1 hour ago, Dose Pipe Sutututu said:
are those the cylinder head to block bolts that go on the outside??
That's what I thought they were when I saw the pic. I thought there was one front and one rear though not both at the same end?
Yes correct. 2x M6 bolts
1 at front intake side and 2 at rear either side.
I should note that i never put them back in any of my engines. With RB25's you can't access the front bolt without taking the inlet manifold off which is a shit job which annoys me as i would rather take the inlet manifold off when the head is out of the car.
Yea they didn't go back on my engine either lol
ahhh I installed coppery colours ones back into those holes.. interesting those bolts I took a photo of, I wouldn't' think they would fit as they're wider than the golden/copper ones I used from the R33 motor.
mad, no fear - didn't fk up
Update but no photos (taking inspiration from @luke gtr lol).
Removed R33 plenum, installed bottom half of R34 plenum.
Now awaiting 1550cc Bosch injectors and a Plazmaman rail. The initial plan was to use the 875cc Siemen DEKA V I had from my old motor but anticipating the power this motor will make there's no way those injectors would cut it, even if I ran 4 bar base pressure.
Been trying to order parts again from Andrew @kudos.motorsports but he isn't replying to my emails :(
Update but no photos (taking inspiration from [mention=37584]luke gtr[/mention] lol).
Been trying to order parts again from Andrew [mention=1172]kudos.motorsports[/mention] but he isn't replying to my emails [emoji20]
Nawww, thanks brosef.
1 hour ago, ActionDan said:
Side feed in that boat anchor engine aren't they?
yeah nah cuz.. I had top feeds in there under the stock plenum before they were even mainstream :)
http://www.trak-life.com/diy-converting-top-feed-injectors-r33-gts-t-skyline-rb25det/
Yah... stainless internals, not modified by any laser cutter/mill/bench grinder/side cutters
US guys usually refer to them as Siemens DEKA V 80lb
I hate modified injectors, those "Bosch 1250cc" are milled.
