Drove it tonight, gave it a bit of a squirt on the new motor. Does feel strong, but haven't given it a beating yet as it's still the 1st batch of oil.
Will dump out the oil then drive it harder this weekend :)
Not a bad turbo, comes on (gate pressure) about 4000rpm, from the trace you can see 0.8bar of boost by 3600rpm. Mind you this was all in 2nd gear. No 3rd gear squirts yet hehehehe
@Piggaz told you I was going to give it not pussy it around!!
  • Like 4
50 minutes ago, niZmO_Man said:
But does it dose?
not VL dose, but it is because running low boost and also has a stainless intake..will take the car and get some fab work soon ish :)
Haven't driven the car since but installed a modern head unit with bluetooth for hands free life :)
Some modern features for an prehistoric car.
2 hours ago, sneakey pete said:
If you can hear the radio you're not driving it fast enough...
That's what i tell myself anyway, need to get mine working again...
Haha its got some decent audio, Vifa splits and a DD ported sub. At the back there is a 4 channel and a monoblock to power the speakers lolol.
So late arvo yesterday, dropped the oil and put in fresh 15W50 Penrite Racing and decided to check the base timing. It was a whole 4 degrees off. Explains why the car had a bit of a boost creep running stock gate pressure.
Fixed that, then took it for a spin (in between that fixing the fuel table which didn't require much change from the old motor setup). Got the AFRs a bit leaner so now its hitting 11.7 and flat lining.
And yep, I raised the boost too haha.. Running it in at 1.2bar of boost with crap all flat timing it's baking shitty 245 section Dunlops. Took it to Mexico and wound out 1st 2nd and 3rd, think I'm starting to hate the car less. Followed by that ended up at my mate's shop in South Mexico followed by a session of donuts to bed in the motor further. Gave the keys to the other boys at for a spin too. One didn't mind the lag as the motor revved out to 8.3k the other said was a bit too laggy for his liking but nevertheless still put a smile on everyone's face.
Late last night thought I would try to download the footage from my dash cam, turns out the memory card is corrupted :(
  • Like 2
I'm running in this car a shitty Laser branded dash cam. It's the same as the G1W you see on OzBargain.
Also isn't the first time it has corrupted a memory card. Instructions clearly state only use memory cards in this list, clearly I'm not lol.. Have a SanDisk SD card in there it doesn't like.
I don't think it matters, I've got an older GoPro4 and a quality SanDisk card and it never seems to capture anything when I'm doing illegal stuff, it's really odd.
Ordered 2x 3.5" v bands, came next day.. Woo! (One pictured)
More exhaust mods, 3.5" into a 3" axle back isn't going to be optimal for 400kW+ worth of exhaust flow. Gotta open up that shit
  • Like 1
A bit of raw data from the car, we can see it's making boost within 200ms or so from gear changes. Not bad transient response :)
It's no EFR or GTX but for what it is it will make many GT-R owners with twins pretty sad lol
Haven't had the chance to give it a full belt and do logs because of the long weekend
  • Like 1
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
