Weird how the battery has been ok, till when I decide to go grocery shopping.
Lucky enough bumped into my mate, also grocery shopping lol. Clearly the ladies in both our families aren't trained well.
  • Like 2
In pursuit of a quiet gentleman's car, ive decided to add more mufflers :)
Proposed new set up will have a cat still, and the external plumbed back after the 100 cell cat.
Both exhaust and gate will merge into a small cylindrical muffler, then into an oval muffler and then a large fk off muffler. All 3.5", hopefully I can hear all the squeaks in the car and all the noise from the rose joint arms lol.
LHS = Hi-Tec (extremely heavy, stainless but ends are sprayed black)
RHS = SMB last of them forever I think. They've shut shop as the owner is ill :(
All 3.5"
  • Like 1
All 3.5"
I decided on magnaflow so went down to a place near by to get them, they actually suggested to me to use smb but it was christmas time and they had already closed for the break.
I went home thinking smb and ordered some other mufflers for it online lol funny how that seems to happen.....
48 minutes ago, Jordy32 said:
Oh that's a nice seat!
May I ask the price? I'm thinking of selling my brix 1.5 for a fixed back.
Thanks man!
Was about $1.6k with rails from Jesse Streeter, however we ordered a bunch of other shit too.
24 minutes ago, timmy_89 said:
when did you turn so soft :4_joy::4_joy:
shu habibi, wot do you meannnnnnnnnn? lol
Still, if you came to my house tonight with a 335i, 4 door, N55 motor, under 80 000 km, clean (not perfect) M Sports version, well maintained and a slab of beer in the back I would straight swap you the R33 and all my tools, minus the tool chest itself.
  • Like 1
Pfft.... no chest no deal :4_joy:
you no deal :)
Tool chest was a birthday gift from the missus, that stays.. everything else inside comes with the car LOL
  • Haha 1
On 2/6/2018 at 12:22 PM, AngryRB said:
?.. where was the dose??
Took @Piggaz for a spin yesterday, he confirmed dose was there and sounded gay LOL.. also confirmed single turbos are better than twins LOL
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
