And as it was running ok, she's off the road again lol. Nissan life, spends more time off the road than on the road.
Photos are self explanatory and for the not so visible I will be running 2x Wallahbro 460L/h pumps off 2x SSR for PWM. This should allow me to control the fuel pumps based on engine load. Benefits of this are tremendous, less heat generated, less noise when doodling around, lower current drawn when engine is at lower RPM and not to mention it is just cool lol. This is one of the many reason why I've moved to a Haltech Elite 2500, although the Adaptronic is more than capable for 90% of the applications out there. Thinking about it hard enough, I could have even used the boost solenoid output of the ECU to control the fuel pumps :)
(Yes we are a Haltech club, that's Henry from Hensperformance, small one man band that turbo charges lancers and mirages, asked him to help out to get the car on the road quicker)
  • Like 3
16 minutes ago, iruvyouskyrine said:
What SSR will you be using?
Just the Jaycar shit, big enough and fast enough 1 ms (0.5 ms release and 0.5 ms on) response which translates to 1000hz. More than fast enough for what I need it for.
16 hours ago, TimmyMA70 said:
I just finished reading your build man, really good read! Heaps of detail too Love it.
Cheers man! It has been a shit journey but I'm nearly there!
Also in other news, after removing about 10kg worth of amplifiers something needs to go back in so I've opted for small and lightweight Clarion Marine amps, perfect for the boat.
These will be fitted on the LHS next to the battery where as my old set up had 2x large amplifiers stacked on top over the fuel tank access.
  • Like 1
51 minutes ago, WantGTR said:
This thread was great until this crap about amplifiers
I might look Asian but deep down inside I'm a Leb.
  • Like 1
  • Haha 2
You need marine speakers on the outside of your car so everyone can hear your hectic choonz as you drove through cabramatta
59 minutes ago, niZmO_Man said:
Need the hardstyle to drown out the fuel pumps :P
fuuark need to muzz in the car too, get featured on Muzz Chop Appreciation group man!
shuu, stereo so loud don't even need speakers outside - will give the Ivy a good run for noise
  • Like 1
  • Haha 1
^lol for a state that doesn't allow shots after 12am, no entry/re-entry after 1:30am I wonder why everyone is angry :)
Also good way to kill the economy, because of the lock out laws the statistics look great on paper and the politicians look like real heroes but what about all the unreported crime/violence that happens?
Anyhow, went to remove my ECU on late Sunday night and surprise surprise, my heater core is weeping. Entire passenger foot well is damp, explains the horrific smell in the car.
  • Sad 1
What's your plan with the heater core leak mate?
Looks like dash out/replace :(
This is a street/track car so at very rare times I do drive it here and there (as it's quite streetable, has decent audio/AC, etc.)
Yep, I get that completely mate. Same as my setup. I replaced mine while the dash was out for good measure.
Hit me up if you want me to look up the genuine Nissan part number on FAST for you ;)
Thanks Timmy! But I've already ordered some overnight parts from Queensland lolol
Thanks to @kudos.motorsports and the team there! (Not sure if Andrew even goes here anymore).
In other news some progress on the fuel system. Using both the OEM feed and return and merging it into a 8AN to be used as a return line from the rail. All bulk heads installed too, 2x 8AN for feed/return from rail and 2x 6AN for the supply/flex sensor and pre filter.
Still a shit box but no dodgy shit here, I've seen shops where lines are fed straight through the body work. Dodgy AF.
  • Like 1
  • Thanks 1
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
