Made up some lines, will try to get all the lines run by Sunday. Getting good speed with work as I have a couple of mates helping too.
  • Like 3
8 minutes ago, niZmO_Man said:
inb4 "car is now entered into WTAC"
Will be first one entering with stereo system installed.
Updates to shit box, lift pump done. Using a DW200 pump which is quiet, low current thus generating low amounts of heat. This will be running just off the stock wiring with the OEM resistor deleted for less aids
Now to the feed, pre filter and flex sensor. That's a shorter version of the continental flex sensor (Not the Micro) and a 65 micron filter.This will incorporate a U turn just to get everything neatly tucked next to the fuel tank lid. Should look super sex once the trim is in. You won't be able to see anything :)
And yes, repurposed my old supply pump with a new Wallahbro 460. These are both the F90000267 version (wanted to keep them matched). Doubt I would need the high pressure relief version.
And that's a wrap this weekend!
  • Like 4
In other news, my heater core split. Explains why I was losing coolant and not being to work out where it is was going...... Until I removed the ECU to sell it, found a nice Olympic sized swimming pool in the passenger foot well.
Massive karnt of a job, maximum aids.
20180719_215425.thumb.jpg.e88df231bcb11304c8d755cdccaabf87.jpg0
2 hours ago, Ben C34 said:
Dose man, what frequency do you plan to run the PWM modulation of the pumps? From what I have seen it needs to be quite high.
haven't really worked out that yet lol
Will do a bit of maths when the time comes, currently car is on the hoist looking pretty - too cold to work on it
  • Like 1
Actually I did the maths before :)
On 6/27/2018 at 8:52 AM, Dose Pipe Sutututu said:
Just the Jaycar shit, big enough and fast enough 1 ms (0.5 ms release and 0.5 ms on) response which translates to 1000hz. More than fast enough for what I need it for.
Is that really maths?
Wouldnt that be 1000hz of doing nothing ? not a useable range of modulation due to the wasted on and off time.
from what i can tell the proper systems use way higher pulse rates, like 15000Hz, which is smoother for the motor, and they dont use ssr's rather some other thing with MOSFETS or other gadgetry.
that is very true, but this is a shitty fuel pump not a jet liner in the sky lol
Haltech actually recommends you start at 100hz as per their online guide
Made one more line for the surge and spent most of the evening removing all my old gauges, sensor cabling, EBC, alarm wiring and schizzle. Will be making one clean loom from the ECU all the way into the engine bay (driver side). Yep, looks like I'm getting a dash :(
3 minutes ago, WantGTR said:
is this still a street car?
Yeah hard! Has AC & working climate control, sound system (twin amps, splits, subwoofer lol), airbags, ABS.
Won't have a parachute nor will it do 9s, so street car it is :)
Mocked up the following 2x Jaycar 40 amp SSRs, Narva fuse holder, 65 micron Speedflow filter and Continental flex sensor.
Piece of shit R33 shit box slowing coming together. Still regret doing all this work but can't leave a project half finished.
  • Like 3
Some minor progress, ended up drinking more at the shop rather than doing anything useful lol
Mocked up the wiring, the rubbish should be sleeved soon too.
  • Like 2
