Exciting when you buy new parts, then try to fit them and realise they don't work LOL
PRP R35 Coil Kit - loom doesn't work, Herman changed the design for the kit but didn't get his wiring team to update the harness ?
All good, top bloke is sending me a new harness this week.
842782134_WhatsAppImage2018-11-13at11_02_50AM.thumb.jpeg.ff49742057d9b828a8b6bc0297596a56.jpeg
No exciting update besides me trimming up the carpet this morning lol. Will get another piece and redo it, this was just a trial run.
Kind of tempted to make a new false floor and use marine carpet but yeah a project for 2021.
  • Like 2
57 minutes ago, ActionDan said:
Neat, I like.
Yeah but it's still shit, because I didn't use Pierburg and an Emtron.
25 minutes ago, niZmO_Man said:
I better see this on display at next year's WTAC ;)
Nah, it's not race pedigree enough. Doesn't have an BW EFR and a PPG/Samsonas.
Hey, did you know it's possible to post an update/pic etc, talk about it with people, and not take yet another unprovoked dig at everyone elses parts choices at the same time?
#stopbeingsuchasaltybitch
Love you xox
  • Like 2
Love you xox
I've been told by several people multiple times that Haltechs make motors turn backwards and that you need a pile of boxes to make it work.
And rather than sook about it, how about you just ignore it and keep doing whatever the f**k you want?
Post more skid vids, I don't need another episode of Degrassi Junior High up in here.
Going to SMSP next Thursday :)
Dori Dori battles.
Hasn't seen any dyno time, but I'm sure no rods will bend #becausebuiltmotor
Has pretty relaxed timing of 13 at peak torque and 16 up top at 1.3bar boost. Rev limiter set at 8500rpm ?
Yeah, heard 95% of his tuning work is on SR20s - not sure why he wants to tune this shit box :)
Not yet, just ironing out some small issues, need to finish off the exhaust then fit a 100mm Plazmaman cooler - then it's show time.
I think I'm getting massive fuel pulsation at around 3500rpm which is causing a misfire, however the fuel pressure (logged) doesn't show any fuel pressure fluctuation. Will move the Radium FPD higher up towards the rail and see if that helps.
Do you want to tune my SR when it's done? It will be a baller one so you have to come to me because you will get all that e-fame and exposure by being associated with it...
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
