Is it sold?
I am so confused.
Even I've thought about it from time to time, I bought my GTT for 11k. If I went and dropped a second hand motor in the thing I could palm it off for what now days seems to be double what I originally paid for. Then sell the rest of the parts I have lying around and go buy a c63, m series or 370. Hell even go find a buck80 shell and drop the built motor in that for lulz.
One can only wish for an insane person like yourself or myself to buy an incomplete project!
Would love a 335i F30 or even M3/4 F80 but yeah money doesn't grow on trees and I don't even have a job at the moment :D (my position got made redundant, so did 50 others).
I didn't wanna bring it up as I'm sure it is a shit thing to talk about.
Taking some time before you hunt for work again?
2 minutes ago, ActionDan said:
Doing the reno yourself? Man of many talents.
Everything but the tiling, didn't want to buy more tools and cook up job lol
I only do everything myself because I can't afford some sex spec business to come do it for me, so I DIY lol
I like to try and do as much as I can, but there are some jobs I don't attempt.
I put tiling in that basket, but a mate of mine had a go using youtube clips when he did his bathroom and I have to say it came up as good as I'd expect a tradie to do.
I've got kitchen/bathroom/laundry to do in this place and I'm considering outsourcing the whole lot lol
Haha mate house plumbing is easier than plumbing up cars, especially with the PEX stuff!
Electrical is a piece of piss too, you need to be massively retarded to cook up house wiring!
But yeah I would have preferred to outsource the lot, but I'm an Asian and I'm a tight arse.
Cabinets were all custom ordered and cut to my dimensions then flag packed. Picking them up next week, will be a good surprise lol
  • Like 1
Oh that stuff I do, that's not a reno though. I just see that stuff as basic maintenance work and I do all that. First year apprentice work for a tradie. When I was helping my mate put in our new ducted ac/heater he told me I would make a good TA lo f**k him :D
I was more talking bench tops, cabinets, tiling etc but the flat pack is a good idea.
1 hour ago, Dose Pipe Sutututu said:
Wait till it comes, haven't bought the washing machine yet, but will be German and throw check machine lights lol
Dad bought a Bosch front loader washing machine, it died after 5 years (electronics). The LG one I bought is still going hard after 5 years. Heavy use (6 people in the house).
Samsung 7kg front loader here, we've had it 8yrs so far, 6 of which has been with kids...
I have replaced one water valve (leaking) and I suspect the shocks that hold the barrel are getting tired.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
