Why are Americans so stupid?
Ordered an injector harness, selected I wanted EV1 connectors and then I get sent an OEM replacement harness!
  • Sad 1
Wiring Specialties you stupid fat American pricks.
Alibaba 50c adaptors ftw.
Just now, Ben C34 said:
Fire up that front loader, that will cheer you up. Full speed spin cycle
Good plan, I'll go hang a big shit and get that quick wash cycle on with the rpm set at 1400
  • Like 2
9 hours ago, MBS206 said:
Mate, don't talk shit about these guys, they're the Wiring Specialists.
Lol, no they're just cheaper than the wiring specialists here in Sydney.
I am pretty sure over a decade ago they contacted me on Nissan Silvia asking for my wiring diagram I put together for RB20 swaps in S13s. Anyhow, looks like their warehousing/pick and pack guys cooked up the order. They're sending me a new harness, fking anti-climatic day yesterday.
If I had a wild, open cheque book build the car would go to Benny at Benchmark Solutions for wiring.
52 minutes ago, GTofuS-T said:
the little baggies of coke covering the rims weren't a dead give away?
I can't work out what they were on this phone.
It actually looked like two plastic bags with white rags in them!
And if someone has that much coke, they aren't driving a VY commodore...
Edit: wait, that's a picture someone has printed and placed the baggies on top of yeah?
f**k me, I is dumb Ha ha
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
    • How will O2 sensor voltages help to identify it when it is sputtering?
    • What do LTFTs look like? What do MAF voltages look like? O2 sensor voltages/AFRs? Knowing O2 voltages especially when it sputters would help a lot.
