Surplize modapuckers lol
This happened today, driving back from work like a normal person. Doesn't happen when I drive like a complete knob, or launch it at 4k.
Anyhow tried off and turning it off and on, that didn't help ?
20190927_182351.thumb.jpg.89d2e9fbac9571962b60dbe4603e8d16.jpg20190927_182355.thumb.jpg.5b249c4220d6e9f137a7d4c7b2e7435f.jpg
So headed out to pick up the missus in this shit box, and spanked the limiter, she didn't like it.
  • Haha 1
1 hour ago, r32-25t said:
Typical German car
Lol yeah but considering it's not even 1.5 years old with 17xxx kms on it, it's a joke!
Modern German cars have a system built into the BMCs and CAN that turn on one of a set of random errors each 18 months for the life of the car to ensure you get rid of it and buy a brand new one just after warranty finishes.
  • Like 1
  • Haha 3
It’s why as cool as I think the golf r is I’d never own one, I’d look at either an sti or the Hyundai i30N
  • Like 1
Man my back is sore lol. A fixed bucket seat, semis, several solid suspension arms, rock hard suspension but yeah ended up doing over 450km today. 1.5 tanks of fuel later ?
Good drive with @PLYNX and my mate in his R33.
Okay, admittedly it was pretty fun and first time I've actually stretched the new setup with a lousy tune. Shoots flames, 11:1 afrs, lazy 10 to 12 degrees of timing but it is wanting to light up 255 Nankang AR-1 semi slick tyres. Still need to swap out thr gate spring to a softer spring, running a 4 port solenoid and with a 1bar spring there's very limited resolution, kept spiking and hitting engine protection.
  • Like 7
I'm sorry I missed the run.
I've spent the day yelling at people and driving back from sunny Singo
Glad your beastie got to stretch its legs.
What's next for the 33, back in the garage for a spell?
Umm no idea to be honest, I said I'll try go once a month with @PLYNX but knowing my life, even that would be hard to achieve.
And here's a dose video and some gate, wallah swear to god I didn't use the photo illegally (didn't talk or text or use social media) lol
  • Like 2
43 minutes ago, Murray_Calavera said:
What spring are you planning to swap to and what max boost are you chasing?
0.5 bar and will run up to 2 bar.
At the moment trying to command 1.3 to 1.4bar is very challenging. Every 1% to 2% change in duty cycle is jumping 0.1 to 0.3 bar of boost. By dropping the spring you end up with higher resolution. Just some idiosyncrasies with running a 4 port. Running a 3 port but across both ports on the gate is a simpler solution which allows decent control too, but I wanted to try out a 4 port setup, so here I am lol.
1 hour ago, ActionDan said:
Can't for the life of me think why it would be showing signs of fatigue or damage ;)
Well it's there to use right? lol.
1 minute ago, ActionDan said:
"The brightest candle burns twice as fast"
That's why people run boosted engines, to get twice the atmospheric pressure :)
Another solution I've come up with for another car I tune which granted, we've not tested yet - and I don't know how flexible the Halaltech is with settings and available outputs, but we're running 2 MAC valves and running one of them against a fixed PWM look up table to "bring up the base pressure", then use conventional boost control to drive the second one as an effort to retain 3-port style table granularity but give a 4-port style boost range.
Interesting, is that similar to how anti-phasing works? I hear that terminology thrown around a bit however given we aren't in race cars or F1 cars I've never bothered to read further nor investigate further.
4x port was already going into another level for me haha...
    • Not much. It's barely more than an hour's labour. So that-ish plus a boot, clamp strap, some grease.   But, being an R32 GTR, when it is up in the air and the driveshaft is out, about $9k worth of other problems will become visible.
    • Yes, as above. The welding is an easy enough job. Proper reupholstering, perhaps less so. These, and pretty much all seats of the same era (and probably still) rely on molded foam parts to make the shapes. That foam is the yellow detritus visible in the photos. And it is difficult to replicate. I didn't want the pain, so went aftermarket seats instead. But for "saving a classic".... it's probably worth the kidney and left nut that a trimmer will want to redo them.
    • Way too accurate.... source: got flogged by an unsuspecting i30N last night... Super tidy looking 32 though, hopefully you find the time and funds to get it back on the road and enjoy it again!
    • Source: This thread, and the thread this thread spawned from. Alternative take: Is heat actually an issue for the use case of this vehicle? I wonder if it actually would be. Nekminit
    • Considering the price of GTR stuff now the answer is yes. That's a straight forward TIG or even MIG job. I'd put extra tubing inside, for extra strength and weld it up. Then use the spare seat as an example to get the bolster rails in the correct position and the re-apolster. If you don't mind me asking what did you pay for the pair as they are?
