4 hours ago, Dose Pipe Sutututu said:
@robbo_rb180 they're a pretty decent street/track pad as they give you near track pad performance but a street pad feel, ie not much heat required.
New day, new part, and wasted more money ?
Now to find time to delete the haram clutch dampener.
When I did this I didn’t notice any difference. The R4C feels the same wouldn’t even know I changed my lines
I think I did a potato job at bleeding the clutch before and might not be 100% free of air hence the spongey pedal. At least with this simplification it's going to be much easier to bleed.
1 hour ago, Unzipped Composites said:
Did it feel like you were going to capsize? Coming into turn 2 on the trapeze like:
Lololol.. wallah running trim tabs, dw cuz, Moey Don't Worry said these will fix.
  • Haha 3
7 hours ago, ActionDan said:
Why do you want to damage that car so much lol
Because it's still under warranty, and why buy a SUV and not use it properly right? Out of the Tiguans on the Tiguan group on Facebook I would say I treat mine with the respect it needs. Plenty of LCs, off road adventures and coolant leaks.
3 hours ago, Count Grantleyish said:
Reliability testing.
legit this... will test it until it's nearly out of warranty and will sell it lol
Word
Some people couldn't believe I thrashed my STI along dirt roads in the boondocks of Queensland and NSW.
I cannot see the point of owning a niche car and not beating on that niche.
If not, they should just buy Corolla.
End of old man rant.....
  • Like 1
  • Thanks 1
Oh I get that, some people are upset because my side steps are dented and I've added scratches to what was a fairly neat low k's Prado, but in the end it's just a car and I wanted to go exploring and learning.
That said, you seem to be going a step further and actively trying to break it lol
Broken from usage and broken from rape is different ;)
  • Like 1
  • Haha 1
Somewhat a proper update?
Last Saturday my mate came over to help me remove the diff (because I was lazy and was going to drop the car off at the diff shop instead). Yesterday I dropped the diff unit at Smithfield Diff & Gearbox and today Anthony gave me a call said my diff was locking more on one wheel than the other and the clutch discs inside were fairly scuffed.
He suggested he would clean up the discs, remove the scuff marks and re-arrange the plates so the lock can be evenly distributed. At the same time the diff unit will get new seals, new bearings and backlash re-adjusted (as there was some play, due to wear and tear). Was advised that there will be a little bit of whine as the crown is a little thrashed, however I said that's fine as it's not a street car.
Will be getting it back early next week and will spanner check the car for the 14th of September at Wakefield. Have quite a few mates going:
  • 3x EVOs
  • 2x Mirages (both turbo charged)
  • 3x Nissans
  • 1x Honda with K20 Swap
  • Like 4
pfft, should've heard one of the diffs in my R31. Was louder than a truck air breaking.
  • Haha 1
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
