On 22/02/2022 at 4:04 PM, niZmO_Man said:
yeah try finding parts for a GT-R
anything on EFI Solution site? I can help you with that.
BTW... I might have been told Haltech Elite will be supporting canbus keypads and they have a test version working on the bench. I may or may not have heard that :)
@r32-25t unwire all your old school switches eating up your AVIs, time to get a canbus keypad :D
keypad - Haltech
  • Like 2
keypad - Haltech
I don’t have any switches on the AVIs, I’ve used them all on sensors and need a few more
Remember to use your old afm inputs if you haven't already - there is another 2 AVIs doing nothing otherwise.
  • Like 1
haha, already went there, even used the 2x narrow band inputs too.. I went to town.
No more spare inputs :D
Ive grabbed them and the original O2 sensors
  • Like 1
Same. Don't have Emap but have Exhaust temp.
  • Like 1
On 22/02/2022 at 5:08 PM, r32-25t said:
thats my list and to that I’d still like to add fuel temp and maybe a trim switch which jem have managed to make work with the eboost2
You have flex sensor on an spi yes ? Fuel temp is incorporated into that - no avi required.
  • Like 1
Depends on sensor too, some seem to not send back fuel temp however all the new smaller/compact Continental ones I've setup seem to.
Yeah it’s on that but it’s an older one and I’m not sure if it does temp
Might need to switch it then. From what I've seen the Haltech, VDO, Continental, AC delco and GM ones with the 3 mounting holes measure fuel temp - they all seem to be the same thing if it looks like this. I have a genuine Haltech one on the blue 32 and the white 32 has a VDO one with shorter pipes but same body;
If it is like this below I'm not sure - probably doesn't but I have no experience with them to confirm:
keypad - Haltech
Bit late to the party mate with that.
Haltech have been really adding heaps of stuff lately with this NSP update.
Still waiting on the Mexico trip video........
  • Haha 1
I’ve got the haltech one with the 3 bolt holes so I guess it does it, one less AVI that I need now
  • Like 1
just be sure to select this when configuring the input
And if you really want your fuelling to be spot on, make sure you build out your fuel density table. Most tuners don't bother with this and just rely on the static value density that is default on the Haltech. You really need density vs. fuel temperature to have accurate fuelling. Car idles so much better now with this table defined, also with DBW sure makes A/C, big cams and idle a walk in the park.
  • Like 1
Adam at JEM setup my trim switch to the eBoost settings and also to boost by gear as it’s auto. It works really well
  • Like 1
I saw a video of it and he was talking to me about it when I was there about 6 months ago. If I decide to put an expansion box on it I’ll get it all set up
Forget about the eBoost, 4 port solenoid and canbus keypad.
Have buttons called 400kW, 500kW, 600kW, Rolling A/L, Launch Control, etc.
:D
:D
Mines a dad wagon. I need better names. Wife, Kids, No Kids, Noisy Button etc
  • Haha 3
So this should work
  • Haha 2
Walked in, walked out $550 poorer.
I now have new bonnet/hood insulation 😂
Amayama couldn't source one, Kudos couldn't either, even tried EFI Solutions but somehow Skyline Spares could so yeah, sent it and bought it.
This is more expensive than a coacine addiction.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
