On 24/02/2022 at 12:49 PM, Dose Pipe Sutututu said:
Walked in, walked out $550 poorer.
I now have new bonnet/hood insulation 😂
Amayama couldn't source one, Kudos couldn't either, even tried EFI Solutions but somehow Skyline Spares could so yeah, sent it and bought it.
This is more expensive than a coacine addiction.
Different than 33 GTR right ? Also try JP car parts for stuff. They've sourced things for me Amayama hasn't been able to get or said was discontinued.
  • Like 1
It is a bit different, however both are same same in what they do and how they mount.
I haven't even opened the box yet, just added to my parts museum to install one day :D
I must admit, I didn't really try very hard to locate it - but thanks for the tip with JP Car Parts, will try them next time I need more replacement parts for the shit box.
One sensor issues at a time, worked out why my oil temp was reading out of whack.
Turns out when you run a temperature sensors on a SP Input instead of an AV Input the internal pull up is 10k Ohms not 1k Ohms. This means the standard calibration table cannot be used and needs to be offset.
Haltech did supply me a new calibration table to suit, however advised that the resolution will be reduced.
To fix this small issue, I decided to move the EMAP input to SPI2 and move the Oil Temp input to AVI10 (didn't do this initially as I used the OEM power steering input and pinned it to the OEM AFM and it all sat on the main 24 pins connector).
Instead of cutting, crimping and shrinking I decided to swap it on the ECU side AMP plugs. How good are these AMP plugs? No need for any fancy thin depin tools, etc.? Anyhow was a 5 minute job and hello full range and full resolution oil temperature.
  • Like 1
Actually, be really careful with depinning those AMP connectors....I find them an absolute arsehole to work with. The tabs on the locking cap break easily then you are left with a connector that is almost impossible to seat back in properly locked. I ended up buy 2 new ones out of the US (Haltech would not supply) for a fortune.
Also, they are very fiddly with seating the pins at the right depth, initially is OK but if you repin something you have to make sure every wire is still seated properly as they can back out. Pretty much every other style of connector I've worked with is easier, except for those POS pull through ones like in the pressure senders.
*edit* cancel the locking clip rant, that is a different type of AMP lock they used on the smartwire. The one in your pic looks much better (maybe they redesigned after issues)
Edited by Duncan
clarification
  • Like 1
You're probably thinking of this style of Tyco connectors, these are a complete cnut to get right as per your experiences.
The other end to the plug and play adaptor uses these and yes, I've ended up just wiring direct to ECU instead and bypassing them as they're a cnut to work with 😂
yeah those are have a crappy lock too, but I meant these ones
Same pins and similar body to what you have but the red piece does the locking and is brittle. PITA.
Deutsch is the ones when you have a choice, even their big multi pin connectors are great to work with. Expensive tho.
  • Sad 1
I know that plug, great to build once and never look at again lol.
Yes I also hate, and have replaced the entire auxiliary connector before. Depinning it a nightmare.
Cutting and recrimping is easier, that's saying something!
On 28/02/2022 at 8:32 AM, ActionDan said:
I thought you were coming down to wire and tune????
I barely have time to sleep these days, let alone work on race cars that are 2000km away lol
Found a few minutes spare today, turns out they sold me a GT-R one.
Good enough, just 1x clip hole doesn't like up. I have the option of punching a new hole OR drilling one. Still a bit undecided on what path to take but I'll do it one year.
  • Like 1
On 05/03/2022 at 8:11 AM, WantGTR said:
GTR DNA
thats it boys. pack it up.
Nah failed at that one, has a twin scroll single turbo and has VCT.
Needs no VCT, twin turbos for the lags.
  • Like 1
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
    • After an excellent condition, working! oem radio for a 97 r33 And the steering wheel shroud/cover as mines a little bit scratched up Am in Melbourne
    • So my exhaust is loud and sounds awesome (good thing) but also is very loud when coming and going, dont want to piss off the neighours etc Are the varex adjustable mufflers any good? I contacted them but they dont make r33 specific exhausts Ive also see the adjustable inlets on this site but apparently they might restrict airflow too much which wouldnt be good for the engine. Would prefer something thats adjustable from in cabin so i can change it on the fly, dont really want to put in one of those permanent exhaust tip things.  Any other recommendations would be appreciated!
    • You don't need to lean as far to pour the oil in, or change the spark plugs either 😛
    • Indeed, it is much easier to get at the filter with the engine on a stand
