On 3/27/2022 at 1:43 PM, MBS206 said:
And I was only saying on Friday I wanted a wiring diagram for the window switches, as I want to see how they do it from the factory before I get a double throw switch and 2 relays per window and make my own old school circuit to run them!
easy to use 2 switches & 1 relay.
12v+ to each side opposing & same with negative with centre to window motors
Enjoy my paint wiring diagram
  • Like 1
On 3/27/2022 at 7:18 PM, Dose Pipe Sutututu said:
Just send it, use a PDM @MBS206 wire it to a canbus keypad and then have soft start etc.
People will froth
Buy a Nexus and wire everything and do heaps of other stuff.
Enough outputs for almost any engine setup
I was thinking of just having two switches and no relay. Need to measure peak current on a stalled motor window.
From what i can picture in your setup, i cant see how youre using the relay to remove high current from the switch, your switch has to be in the same side of the circuit as the motor.
Nexxus, ha ha ha ha ha, man, Id love one, but i dont have that coin. Id pay for the roll cage before a Nexxus.
That being said, part of a project I have at work involves a programmable IO module. Its just slightly lower in the order than another project right now. Once done Ill be programming it for my own exact purpose, including a CAN keypad for a lot lower cost than I can purchase a Nexxus for.
Do love the Haltech gear though, want Nexxus, Keypad, and Dash.
  • Like 2
On 3/28/2022 at 9:49 PM, robbo_rb180 said:
I was running a relay so had direct feed from battery without voltage drop can wire 2 relays & low current through switch
Yeah this is wjat i was looking at with dual relay and a switch per window.
Depending on the current, if I can find a good mometary DPDT switch that will take high current, ill use it direct, with the relay just for switching windows off when ignition power is off. From what ive seen, lots of manufactufers do it, hence the lots of arcing amd carbon burn in switches over time.
  • Like 1
Very potato photo, just took it as I was leaving as my mate asked where I was heading in the R33.
Left about 8am and took a very extended drive to Meat Emporium to pick up wagyu lololol.
Night before pulled out the laptop and set 1bar of boost, 17 degrees of timing mid range and 19 up top. Safe as shit and closed loop O2 to take care of the rest.
Gave it many jabs to 8k rpm (limiter is 8500rpm). Must say, it's very linear in terms of power, where as before with smaller cams and the OEM intake manifold/plenum you could feel a big surge of torque coming on.
Probably put it on the dyno soon, when I have time. Alex from Birrong has been asking me when I'm bringing it in, I'm sure he's keen too (as the choice of parts isn't what he's used to putting together).
  • Like 5
Some billet brace goodness 😂
This is the only billet brace I can afford.
Needed a better battery clamp solution as the flimsy clamp from Supercheap wasn't holding the battery in place, especially after cutting off one side of the battery guide on the tray to fit a larger battery.
  • Haha 1
Bit more timing down low once tuned and youll get the surge back :P
years ayearsreduced timing on my 25/30 when it was first put in, as it wasnt yet tuned, may have set it slightly low at only 15 degrees... high mount got hot while i moved the car from one house to another on a 20 minute freeway drive...
and thats how my bonnet lining caught fire...
  • Haha 1
Yeah mine shouldn't ignite, manifold is coated, have a turbo beanie and also the dump is wrapped.
Has survived 2x track days like this without catching on fire. Just binned a motor instead when the cam snapped due to oil starvation.
Should be putting it on the dyno soon, just finding time during the week to tune it has been difficult. Work being aids 😭
Might see if I can convince Birrong to open up on a Saturday 🥲
  • Like 1
Ha ha  sorry i was meaning cruising with low ignition timing (low load area).
With all the coating etc should be okay
haha all good, I have like 30~45 degrees of timing on cruise/vac
Oh right!
Thatllteach me to skim read, ha ha, thought youd gone 17/19 through it all, ha ha ha
On 12/04/2022 at 12:55 PM, MBS206 said:
Oh right!
relax cuzzy, not using a Microguess with 2D tables
  • Haha 1
OEM+ achieved, have a bunch of clips and shit plus the cowl to replace soon (all in boxes).
Hopefully someone with a M3 LCI, white, DCT, sunroof, sub 50k kms, near stock wants to straight swap me for the R33 😂
  • Like 8
On 16/04/2022 at 9:58 PM, Kinkstaah said:
Drive it first, then make a decision.
Historically, If he drives it  there's a 50/50 chance it will break something
Which still makes the Skyline more reliable than a BMW
Yes, yes, and more reliable than a 20 year old Holden as well
Your car is to pretty to swap for a run of the mill BMW that could be mistaken for a Kia from side on
Wind the boost down and enjoy for the next 20 years
  • Like 2
LOL... I seem to break everything I own and drive.
I also have this achievement unlocked
I think that's called being Australian.
I've passed the citizenship test then, no deport to Chyna.
(I'm actually born ere')
  • Haha 1
Man this looks amazing!
  • Like 1
    • The Neat gears use an alternative profile, no? Something different to what normal OEM stuff is. Is the noise at all traceable to that? Reason I ask is that my CW&P are effectively past their use by bate and Neat is the obvious option.
    • Just picked up my first skyline. R34 4 door with an rb25det and manual swap. I’m in the US. It has a bunch of issues but the problem I’m chasing now is the indicator, hazards, and horn do not work. I took out the indicator relay and fuses and tested separately and they seem to be working fine. When I activate the turn signal stalk or the hazard button nothing happens, no clicking, and no dash lights. Same with the horn. What should I test next? The headlights, taillights, and brake lights work fine so I think the stalk is good.
    • RD25 neo... sorry bad joke ill see myself out
    • Sorry just googled Toyota WiLL Vi and wish that I didn't, day ruined, fark etc.
    • So mines not in yet ... which should tell you something ...   I got a set of neat gears as well, took a year to get those. Then the setup was a real tricky one, with all the changes. It seems the shims for the front diffs are in short supply and had to wait two round of custom ones. This was all done by a professional diff builder , not me/diy.   So here we are about to go into 2025 and I do finally have a built front sump / diff / gears.  Just need the mojo to pull out the engine ...   Oh as an aside on the neat gears, they have some whine, mostly on decel. Taken a bit of setup again to get that down to a street car level.
