Keeping this thread on topic. A bit of background, our house has the master bedroom on-top of the garage. So any heat/cold from the garage is pretty much transmitted into the bedroom floor.
Terrible in summer, terrible in winter. As the garage panel door is all aluminium, it's a acts as a massive heatsink. To slow down the effectiveness of this unwanted heatsink I decided to insulate the panels with 20mm Foilboard. Essentially it's just 20mm polystyrene with foil sheets either side. They are $44 a sheet (2.4x1.2m) from Bunnings, one side is reflective foil the other side some green snot colour. Ended up needing 4.5 sheets, could have done 4 if I joined left overs but yeah nah.
I didn't take any pre temperatures but once up I could instantly notice a difference inside the garage at about 11pm. This morning I walked in and also was quite pleasant to be inside. Looks like it worked and not to mention reflects a bit more light off the lights.
$240 (plus foil tape which I haven't applied yet, job for another day).
Also took out the shit box on my Meat Emporium run. This time with the gate plumbed back and more boost 😎
And my silly mate with a built Evo 3 has twisted my arm into going to All Jap Day on the 3rd of July. Will give this "roll racing" thing a go and the faux power cruise sessions a good go. If anyone is around, come say hi!
(Pray to all the gods I don't bin the motor, my track record hasn't been very good lately lololol)
  • Like 8
I did my old garage the same way, huge difference - well done.
Good luck at event, actually act when a warning light comes on and you will be fine.
Rather than setup an oil pressure warning light and buzzer then ignore it when you know the car is suffering oil surge because Race Chrono says you're on track for a PB... Who would do that?!
  • Haha 2
I actually logged in and disabled the engine protection (yeah I did that) LOLOL
Won't be doing that again!
Oh yeah, here's an idle video.
Barely can hear the lumps, running a cat, 1x muffler and 1x massive SMB muffler sure shuts up the car.
  • Like 7
Shit box updates, decided to go through the box of new OEM shit.
Quick wins, replace both cabin light lenses and upgrade from halogen bulbs to LED.
Before with the OEM halogen bulbs and yellowish lenses.
And yeah my Bride Zeta IV seat will go back in for All Jap Day 😎
  • Like 2
Almost too nice now to track it now......
So good you are getting all those little things done as makes it nicer and modern, just need a heap of warning lights and you will have that bmw feeling.
  • Haha 4
I know right, I'm going to All Jap Day in Sydney on the 3rd of July.
They have a few Eastern Creek sprint sessions, which I believe are untimed but I'll give it a crack with Race Chrono running.
Why build a car and not enjoy it right? It's like having a hot missus that you can't have a poke from time to time lol.
  • Haha 4
And along those lines, "turning off safety parameters is like shagging your Mrs sister, only to have your Mrs walk in the door, you may make a PD, or it may just explode"
  • Haha 2
On 28/06/2022 at 6:24 AM, Duncan said:
Still, it can probably chirp second
Hahah with cold tyres 2nd is pretty funny.
On 28/06/2022 at 7:41 AM, robbo_rb180 said:
how does it feel on the street?
How much torque did it end up making?
With that zf 8hp gearbox will be a weapon
On the street it's very linear, wasn't like any of my previous setups. The power is very very linear, a way to describe it is like a NA.
Here's a run on 0.5bar boost, power is ruler flat (minus the part where I turned off VCT a bit earlier)
Torque (derived) wise it made 611nm at 6400rpm
  • Like 3
House purchases, renovations, samsonas, dct swaps, garage door mods and I’ve forgotten what turbo this has on it.
  • Like 1
  • Haha 2
@RBW49N lolololol...
It has a Garrett GTX3576R Gen 2 with a T3 1.01 divided rear housing.
turbine side was pretty much on point, just undersized the compressor LOL.
  • Thanks 1
Here's the final power run, you see me looking at Alex quite a bit incase something didn't sound right so I could abort the run.
We did have misfires a few runs previously that sounded oddly like knock, ended up gapping down to 0.4mm on BCP7RES and that solved the issue.
  • Like 5
On 6/29/2022 at 10:14 AM, Dose Pipe Sutututu said:
And log of the final run :)
Will go decat OR 50 cell cat for next session lol
Is the car still on a flex setup or is it straight e85 now?
Looking at the base timing makes me feel anxious (thinking there is more timing in it from the e85 compensation table) but if that base timing is pretty much the total amount of timing then I can sleep at night again lol.
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
