Hey @Murray_Calavera the car has always been on full flex :)
I stopped using compensation tables and have moved to a more 4D table approach, where the slider dictates which map I am on (anything in between is interpolated).
On 29/06/2022 at 1:26 PM, Murray_Calavera said:
Nice, I haven't seen that done before. Is there an advantage of using a 4D table vs a compensation table or is it purely an ease of use thing?
4D table allows you to say have the slider at 0%, 25%, 60%, 80% ethanol as an example, giving you multiple maps if you will.
Also removes the need to do arithmetic when you're tuning, no need to go ahh I need to add 11 to my base table cell of 8 to give me 19.
I "think" it makes tuning a bit easier, however still yields exactly the same results as using the conventional compensation tables as you and I are both well versed on.
  • Like 1
Now with a fresh alignment, a lot less toe in at the rear now as it's no longer needed (subframe offset by 10mm upwards).
Front toe touched up and I think I'm some what ready for All Jap Day, which might end up being cancelled due to the rain.
  • Like 5
Such a good color man. Really looks the business.
Edit: And wheel fitment. And the stubby exhaust. Just well done all round tbh. Awesome to see. So much better than a generic M4.
  • Like 2
On 7/1/2022 at 11:28 AM, Dose Pipe Sutututu said:
@Kinkstaah if someone offered to swap for their M3 F80 LCI I would not say no lol...
still haven't driven one huh
On 7/2/2022 at 2:51 PM, Dose Pipe Sutututu said:
Nope, still would swap lol
Exactly. So go drive one and you can set your mind at ease!
  • Like 2
+1
I made the mistake of buy a car before I really new what they were about, the STI, whilst it was new and comfy, it had no soul at all, and was slow, and reminded me of a Kia
On 7/3/2022 at 8:45 PM, Dose Pipe Sutututu said:
Sounds like me then LOL...
The BMW sounds like a perfect match.
tbh the owner I know who has one whom I got to beat the shit out of in the hills also has a R33 GTR. Would never swap the M4 for the GTR, but it makes for a very nice daily. He actually remarked about how compliant mine was for the bumpy roads without sacrificing grip actually.
The two experiences just aren't comparable. If you find the badge snobbery fun, that's all there is to enjoy about it. Please find one to drive in the hills with your own car as a comparison then consider which set of keys you'd like to keep. I thought the grass was greener too (especially when it pulled up and I sat in it) but after driving both I was like yeah, no way... SavageGeese's review of the M4 did kinda sum up exactly how I felt (though he loved the gearbox, I thought it was really delayed and sluggish)
Well worth a 30 minute watch.
It's personal opinion.
I test drove a stock M4 back to back with a MY11 400+awkw R35 within 30mins of each other back when I was thinking about what I might do after selling the 34R. I'd have taken the M4 as my weekend car on that day, more so for the luxury aspect- but I also have a track car so really it depends what you want to do with the car.
  • Like 1
Did you change the DCT shift aggressiveness? It's a nondescript button next to the shifter, if you leave it in the least aggressive mode it slurs all the shifts and will optimize for fuel economy. If you put it up to max aggression it'll shift hard and fast and be willing to downshift and hold low gears for quite a long time. I do agree that the F80 is a very sterile experience. Put your foot down and you go incredibly fast with very little drama. The S55 also sounds awful and BMW has gone well out of their way to engineer out all the induction and turbo noise from the engine. If you leave it in efficient mode and push the accelerator pedal down just enough to keep the exhaust valves closed while still getting the engine into boost you will hear the slightest hint of turbo spooling but that's it. The suspension in comfort mode is actually very, very soft if you put a tire with a soft sidewall unlike the factory PSS or BMW spec PS4S. I got an R33 because of my experiences with that car knowing that R-chassis cars have all kinds of technical deficiencies relative to something like an F80.
I assure you it was in super sport+ everything available. It definitely did not feel technically better in any form. Slower, worse handling, worse sound, much heavier, way less communication. It was a luxury car that had good power. I felt it a bit shameful calling it a 'competition' anything.
"it's very Type A, it's very technical, it's very engineering focused ....... and now you add in the fact it's now more reliable it appeals to a specific demographic"
"everything about this car is objectively is near perfect, it rides well, the engine is extremely powerful, it's alarming fast, the steering is great, there is nothing I can technically fault this car for"
Sounds like me inside/out, I'll convert it to a single turbo and it will dose and I will be happy.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
