On 7/15/2022 at 5:03 PM, Dose Pipe Sutututu said:
Once you go DBW, you don't look back. Great idle quality, AC doesn't cause idle quality to degrade.
The factory air leak valves are so slow to react, with bigger cams your motor is very inefficient at lower RPMs the compressor engaging is enough to stall the motor.
Nissan should have used stepper motors like JZs or 4Gs, instead they installed a two slow reacting air leak valves lol.
Have you seen the rats nest of hoses under the intake manifold of an RB26? Stepper motors for idle control is far too elegant. On the bright side at least the power steering idle up on these motors isn't a physical valve that can start leaking power steering fluid into the intake with age.
  • Haha 1
On 15/7/2022 at 11:12 PM, Dose Pipe Sutututu said:
Used up everyone single DPI, AVI. Even sacrificed the power steering input lol.
DBW uses up 4x inputs.
How many extra i/o’s does if use.
The fact they fitted 2 of them always confused me
Drive by wire uses 4 AVIs and the 2 dbw driver wires
brake and clutch pedal use one each
  • Like 1
  • Thanks 1
Thanks Looks like I’ll need an i/o expander. May as well get a can button panel as well. No clutch pedal on mine. So I saved one there
To free up some AVIs you can cheat with the temperature sensors and use them on SPIs and change the scaling of the sensor to suit
the drive by wire AVIs must be on the ecu and can’t be in the i/o box
  • Like 1
On 7/16/2022 at 12:27 PM, r32-25t said:
Did you not already fit a brake pedal input when going to dbw as fail safe if something goes to shit?
Is that even a thing?
I’ll have to move some other stuff to the I/o box then. Probably auto controls
On 7/16/2022 at 1:05 PM, RBW49N said:
Try doing a brake job in a modern car with a factory ecu
That's a different story.
In relation to aftermarket ecus with dbw I have never seen them need a brake pedal input as part of the safety system.
  • Like 1
When you select drive by wire in the haltech ecu it pushes you to set up a brake pedal input so that if the pedal says be closed and the brake pedal is saying you want to stop but the throttle isn’t closed it will put it straight into limp mode
Interesting. Link ecus definitely dont do that, nor do motec from my experience.
it deosnt make sense, because all that matters is the pedal and the throttle relationship. If the pedal is lifted and the throttle is still open it should go to safety conditions straight away, regardless if you push the brake or not. Can't see how it helps at all.
Also I am assuming you mean  a mismatch between the pedal and throttle and foot on the brake makes it go into safety mode, otherwise you wouldn't be able to do burnouts and that would be dumb!
Anyway I looked it up and it is optional to have the brake pedal as part of dbw safety with Haltech, and it doesnt relate to a failsafe function really anyway compared to having to have a primary and secondary position sensor on both Pedal and throttle.
Brake Pedal Check  Enable if a Brake Pedal Switch has been wired and configured. Enabling this function will enable the Max Brake TPS Setting. This setting will override all other commanded throttle values.
From
https://support.haltech.com/portal/en/kb/articles/drive-by-wire-elite
can't see why anyone would actually do it.
  • Like 1
The brake input is optional on the Haltech, I personally don't use the brake input.
I'll post up my IO assignment tonight, unfortunately using SPI for temperature sensors are not recommended as you lose resolution.
  • Like 1
On 7/16/2022 at 4:36 PM, r32-25t said:
I hooked up both my brake and clutch pedals into the ecu all my temp sensors are on AVI except fuel
So are you using a lower throttle plate max opening with brake pressed?
On 16/7/2022 at 5:25 PM, Duncan said:
using a brake pedal override seems like a nightmare for left foot braking/trail braking, and burnouts for that matter
Sounds like a great excuse to have a “hoon” “race” button on the CAN keypad
  • Haha 1
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
