On 15/08/2022 at 2:13 PM, Dose Pipe Sutututu said:
Kind of can, I have a feeling there will be max level of anxiety on the day lol...
I have a Garmin VIRB which tracks a few data points such as laptime, speed, Gs, etc.
yeah ok cool
Harry's laptimer is pretty cheap for what it is
https://www.gps-laptimer.de/products
If you just want video with overlay the Petrolhead version is like $20
I got the full Grand Prix version at like $30, just more features i may or may not use haha
  • Like 1
See how I go, if I start to get back into circuit racing like before I might just buy this:
https://www.garmin.com/en-AU/p/690726
On 15/08/2022 at 2:19 PM, ActionDan said:
Race Chrono (paid) gets my vote, controls the GoPro as a rempote and does overlays on the video for you.
Nice, I havent used Race Chrono.
Harry's does multi cam too, with video in video. But havent played with the 2nd camera options yet. I do have a gopro8 so may be something ill try down the track.
Watching these replays has really helps improve my driving lines and lap times.
Damn!! Maybe worth while if you were a pro driver
Overkill for us weekend warriors haha
I know someone who has one and its amazing but he is funded by bank of dad and is serious about getting to supercars.
Takes video of fastest parts and makes a perfect lap, will tell you when to brake too.
  • Like 1
"Takes video of fastest parts and makes a perfect lap, will tell you when to brake too."
thats a pretty cool feature.
Let's just say that private track day, I might have one of those strapped in the car for testing 😎
I'll reveal a bit more after the day.
  • Like 2
Awesome, be good to see how you go.
On 15/8/2022 at 12:47 PM, Dose Pipe Sutututu said:
Lunch time tingz
Added stickers 😅
Now I need to see if R33 and C34 have the same ashtray as that fits well
Doooo it, you need it lol.
Just a note, you need to clearance the trim to clear the Deutsch connector but nothing a 22mm hole saw bit can't fix.
So does trackaddict, though I would suspect RaceChrono paid (which I also have) does well, but trackaddict also overlays OBD2 data from the car if you want that too. Maybe Racechrono does. Point being, get it setup right and all you have to do is hit 'record' and your video and telemetry gets synced and life is good.
Will see how well this all works for me on sept 2 :P
  • Like 3
Latched Launch Control. G4+ and G4x have this feature. Just push and hold the button and the engine won’t rev passed that point.
I have it installed for roll racing, grab the button at 4500rpm+ and it will make boost then release for warp speed
  • Like 1
    • Hey all, I'm working on a project car and I believe I made some mistakes. I'm looking to remove the clear coat from my car on most panels (except for panels where the paint has blistered, I will sand this), but wanted to know if these steps are correct?   1) Get a red scuff pad (abrasive one) instead of sand paper to remove the shine from the surface 2) get 400 grit sand paper and go over the entire car with a random orbital sander so the surface is smooth and the primer can grab onto something 3) On the blistered paint, go over it with around 120 grit sand paper, go to 240 to smooth out the scratches, then finish on 400 grit. Anything to add in here or any feedback?
    • Agreed, another vote for the Haltech CAN wideband.  No voltage offset errors is a beautiful thing.
    • Just get a Haltech CAN wideband, no need to wire any delay circuits, or relay, etc. Since I've moved to a Haltech CANbus wideband, I have not replaced a single sensor for over 5 years (if not longer, can't remember when moved to Haltach).
    • Small analogue delay circuit with a relay. Just need a trigger, say, fuel pump running for more than 5s or so? Or, you could go full mental and write a sketch for an Arduino.
