1 hour ago, Dose Pipe Sutututu said:
I've donated enough to the Nissan car gods lol...
The more I spend on this shit box, the less money I have to put towards a fast, stock, modern car.
That is slower, less fun, and less reliable in every single way.. not to mention much more expensive.
  • Like 1
  • 3 weeks later...
Picked up this mud kitchen from PL Fabrication for free. I assume I've spent enough money there so the least he could do is give it away for free LOL.
Anyhow, lightly sanded the cnut down and then hit it with Dulux outdoor paint, can't remember what colour it is (missus chose it) but I'm a bit colour blind so let's call it light grey. I suppose you could say #builtnotbought lol.
Next will fit a water dispenser.
  • Like 3
Drove to Scarborough for lunch, snapper fish pie was decent, even had prawns in it.
Then drove home, gave it a hit and kissed the limiter and left my 50km old PS belt somewhere on the highway lol.
Shitbox tings.
  • Like 3
Yuh, PS belts are a bit like the inside of the engine. If you touch it, it will f**k up again immediately. I shredded a brand new PS belt. Threw another one on, taking just as much care as the first time (ie, enough) and at some later time had a look in the bay for another reason and found the belt had come off over the front of the pulley and was running with one rib off. WTF!? So the usual full dismantle of the intake piping etc ensued, to provide access to the PS pump area to back it off and prise it back on. Bastard things.
  • Haha 1
RB shit box curse.
Don't see JZs with this problem.
Just waiting on the Ross PS idler kit to come, hopefully a good bandaid.
I hate this car, literally drive the heap of shit once a month and of course once a month something breaks, albeit small.
#90sJDMshitbox
Needs more LS, I literally thrash the bejebus out of the bogan cruise ship every day, started at 260ish killer wasps, now around 360 killer wasps, stock heads, stock bottom end, not to shabby for a old dinosaur push rod engine
Over the 2 odd years I've had it it has racked up about 35k km, and at 150k km it is basically only just run in
It never uses oil, never really breaks, apart from the usual maintenance for a 20 year old mass produced shit box
You should buy that BMW
  • Like 1
  • Haha 1
I need to buy that BMW, first just need to offload this shit box.
Funny how Nissan went from a 4 rib to a 3 rib then back to a 4 rib belt power steering belt throughout the shit box RB era.
I suppose revving the car 2700rpm past its intended rev limiter doesn't help either LOL.
  • Haha 1
2 hours ago, Dose Pipe Sutututu said:
RB shit box curse.
#90sJDMshitbox
Never had this issue with an stock balancer or the ati
You have a 4 rib PS belt, for whatever reason they threw the intern to design the R33 RB25DET PS and he/she thought a 3 rib belt would have been great on the R33 RB25DET.
They probably realised it was a bad idea, a generation later they went back to a 4 rib.
Shitbox tings.
What day did you come down?
Did you see this?
This is at the northern end of Sea Cliff Bridge.
apparently Liam Lawson did 3 laps of the bridge on the weekend
promo video before it runs at Bathurst
There is a vid on tictok of it doing a spin to turn around but I cant forward the link
Did you see this?
Wow, that's hectic!
I was there on Friday during my lunch break 😅
yeah for sure!!
Spewin I missed it
They didnt tell anyone so not many ppl saw it. cops just closed the road for a while hahaha, similar to the harbour bridge movie shooting the other day
There is a vid on the FB page for "Wollongong Sporting Car Club - Home of Huntley Hillclimb"
if you wanna see it lol
  • Like 1
Just had a look, very cool.
They probably don't announce it so they don't draw a crowd. Makes filming and risk management much easier.
Meanwhile, donating more money to the car gods. Some donate to charities, some donate to churches, some to pokies, I donate to car gods.
2029226714_Screenshot_20230131-1038232.thumb.png.042ea8e52e6d5b3ee9bfdf539a4489a9.png
  • Like 2
30 minutes ago, r32-25t said:
You spelt astra pump wrong
Man the thought of implementing it scares me, I have no time these days and no space to take on such projects.
Also not keen on getting a shop to do it because they would charge too much.
35 minutes ago, r32-25t said:
It’s stupidly easy, 2 hoses and 3 wires (+ve, -ve, trigger)
It's the mounting, and making hose part that is giving me anxiety lol.
Sure, I plumbed my fuel and oil system myself but yeah nah I'm done with doing shit now.
Which Astra pump do you use?
Is there a certain year range, and do you end up buying from a wrecker and rebuilding, or is someone selling them new (with Holden now goneskies)
I got one second hand off eBay and it came with the bracket that I modified to install it, I can’t remember what generation it came off
https://www.ebay.com.au/itm/204211245022?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=6vyr4BQfQdW&sssrc=2349624&ssuid=qpegKwgQSeq&var=&widget_ver=artemis&media=COPY
  • Like 1
Cheers Brett!
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
