22 hours ago, MBS206 said:
Which Astra pump do you use?
Is there a certain year range, and do you end up buying from a wrecker and rebuilding, or is someone selling them new (with Holden now goneskies)
TS astra 2001ish
  • Like 1
Your still driving this boat, thought you would have that bmw already. The western Sydney locals aren't selling enough kebabs?
I found a cheap way to keep the belt on was use a 5mm shorter one. Seems to have worked for me. I think my balancer is a 2010ish Ross one.
If you decide to go electric a company in qld converts steering shaft with electric motors instead. A lot of the drifters are going that way, sure could use a PWM output on the kebabtech to control feeling.
  • Like 1
I need, as Andrew Hawkins calls it, "A Western Sydney mode". Just need to install an exhaust cut straight after the dump/down pipe.
Then pop up a few tiktok and snap chat videos then it should sell right? If not try one of the 25 raffle businesses out there 😂
I'll see how the Ross PS idler kit goes, it should arrive by the end of the week. I suspect running a shorter belt "may" work, however having an idler pushed against the belt would definitely aid in keeping the belt on. I know for a fact it's high RPM related and not balancer related as it was happening before with the old motor at skid pans when I manged the limiter, albeit was only at 8000rpm back then.
If all else fails, electric power steering it is. Which also means beefing up the electrical system too. At this point I really should just get a better car instead of slapping more bandaids.
  • Like 1
Your better car will need these mods for motorsport too.
(I guess maybe not with regards to full electric steering, which all reviews universally hate... so I mean there's that)
  • Sad 1
49 minutes ago, WR33KD said:
In the 6 years I have had my 33 never once spat a belt. Don’t even have a fancy balancer, still stock.
What's your rev limiter set at?
  • Haha 1
14 hours ago, Dose Pipe Sutututu said:
I need a new hobby that's not financially and mentally draining
I've heard knitting is hot right now.
  • Haha 2
Don't get dogs, or cats, or children, or a GF then :P
  • Haha 3
The new car mods will be primarily centred on how to stop the TCS and Stability system working. 😛
Buy a big old classic cruiser/VIP style of car, without all of the typical #becauseracecar over the top mods, and don't beat on it
Weekend cruises with the family is where it's at
Slow and low
Edited by niZmO_Man
get off the Enter key ffs
On 02/02/2023 at 12:45 PM, Dose Pipe Sutututu said:
It has arrived...
I've run the idler kit for years and haven't had a belt issue since. My car randomly started throwing steer belts at high RPM and Ross sent me one of those kits and never had an issue again. I considered going electric steering etc but for now it works and while it works I'll keep using it.
Flicking a steer belt may not sound like much of an issue but with the castor/alignment I run and the wheel size etc the steering returns to centre and is heavy af once the belt comes off... Not ideal when you are driving at a wall on track!
  • Like 2
Yeah I've only ever lost a belt once but it was as I came into turn 2 at wakie....when you are not ready for it in a modern car with big tyres, high caster, small steering wheel and low steering gearing you are going off
I dead set thought I had broken something because it all went bad so suddenly
  • Like 2
Exactly what happened when mine came off... Seemed to happen on decel after the kink and I took the scenic route to turn 3 lol... Luckily those were the street car days when my front bar was about 4ft off the ground!
  • Like 1
This is my exact experience too!
However I notice the chances of it coming off usually is above 7500rpm. Anything below seems to stay on the PS & balancer.
I'm heading out to Eastern Creek to try GP Circuit again later this month, hopefully won't be spitting off a PS belt down into any of the turns because all that equals too is a binned car.
Win it or bin it!
Yes, at Wakie with the smaller FP 3076 turbo I was holding 4th gear till 8300 or so RPM as it saved a shift to 5th but with the new EFR and bigger HP I would shift to 5th much earlier and it has a much higher terminal speed at the end of the straight.  So experience with belts flying off sound very similar!
Hopefully Ill have mine on GP circuit later in the year... Been years since I ran it, I think last outing I had some issues but still managed a 1.39... Should go much quicker now though so set me a target to chase :P
  • Like 1
Wow you're absolutely flying! @34GeeTeeTee
Then again your car is made for it, I still have a full street car with working AC, heating, subwoofer lololol.
Here's hoping I get it down to 1m50s with street tyres. If I can do that, I'm going to stop trying to go faster.
Meanwhile, I took a day off to hang out with my son as his grandparents can't look after him today and my wife is back 4 days a week at work.
During his nap I managed to work on the shit box. Installed the Ross Performance idler, dabbed a bit of loctite on it too because I'm paranoid. Then swapped out the reverse light switch after realising I bought this thing years ago.
Ignore the oil mist, that was from last event when I ran an oil cap without a seal... Smart one, entire engine bay was covered in a fine layer of oil. My attempts of cleaning the engine bay wasn't good either so there's heaps of residual oil and/or dried up degreaser.
  • Like 1
If it works for @34GeeTeeTee and @bcozican on their tracks1ut cars then it should work for my shit box.
PS idler seems to be doing its job, and yeah some brap footage just because.
  • Like 3
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
    • I agree, and yet my "HRM " hat is also on, as his wideband is in disagreement with the narrowband where they used to play closer attention to each other.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
