6 hours ago, Dose Pipe Sutututu said:
Add it to your list of things to do 😂
More than happy to explain it and take you through it, alternatively you could use a PDM and double up outputs to allow 50A loads.
I went down this route because I set it up years ago before PDMs were a common thing.
Been meaning to tidy it up for years, and install a 2nd SSR. Found the time to do it now, since I'm not working (on paternity leave). It's amazing how motivated I am now because I'm not working my normal job. It's like my corporate job drains my soul of everything else.
Today, finished off the wiring from SSR to fuel pumps, I integrated fly back diodes into the wiring for sex appeal, instead of running them externally over the surge terminals.
It's a long list....  😅
Yeah definitely looks a lot neater than across the terminals,  good job!  You should start your own little Asian sweatshop now you're pumping out the kids and off work.  Get the kids swinging off the soldering iron bangin out custom PWM setups for Skylines! 🤣
LOLOLOL brah, there's no solder in that setup 🙂
Watching too many HP Academy videos and reading up on the Motorsport Wiring page on Facebook.
Would be nice if I could use the kids to build stuff I could sell, works for me 😂
  • Haha 2
It is good to stay away from solder, particularly in track use, as the vibration and heat from the soldering can break adjacent wires.
You won't find any solder in a factory harness, even back to the mid 80s
30 minutes ago, niZmO_Man said:
sounds like you need a bigger TV :P
LOL.. I do not, I wanted a smaller one and my wife said let's go a size up.
  • Haha 2
as the bishop said to the actress
Today, unboxed a box of new random shit I've collected over the years.
Fitted up new window stabilisers, as the old ones (most likely from factory) have worn down to the metal and ate the tint.
This also means I'll be getting the car re-tinted. Booked in next week for tint removal and re-tint in legal ceramic tint. The current one is stupid dark and also has started to go purple.
  • Like 1
Also re-fitted up infant seat mounts, this required me to attack those pretty speakers with a Dremel to allow the brackets to fit nicely against the car.
FB and wreckers wanted $50 for these brackets, I ended up buying them new for the same price from:
https://rawsparts.com/nissan_skyline_r33/98-r33-gtr-cra-kit.html
Bah. Who needs tweeters in the parcel shelf anyway? I don't even have full range speakers in the shelf. Just 6.5" woofers suited to infinite baffle or very large enclosure. Driven from subwoofer output, no shitty treble.
Sound stage in my car is 100% from the front. Much better imaging.
@GTSBoy those speakers have the gain on quite low, merely there for fill and the odd time I drive around with no sub in the boot it adds a bit of bass back into the system when I turn off the high pass.
Also, if anyone has a keen eye, those are Jaycar Response Kevlar speakers from the early 2000s.
Agreed rear speakers are useless, however I had them lying around in a box for nearly two decades so slapped them in when I removed the ghastly horrible 6x9s the previous owner put in back then.
Front stage has (also discontinued ancient stock) Jaycar Vifa 6.5" with Ribbon Tweeters, a bit harsh for my liking so (maybe or never) might replace with a pair of Morel Maximo if I feel like donating more money to the car vortex lol.
1 minute ago, Duncan said:
Autosalon, my favourite car event. So classy.
Could have at least polished some of the scratches out!
  • Haha 2
 I ended up tearing up my same vintage kevlar Response drivers in the front doors, after one got wet and corroded the voice coil area. Had to make up these bad boys to replace the flimsy masonite panels that had been in there for years. Still running the Response dome tweeters and crossovers against these. Sounds great. The extra work put into the mounting baffle and sealing were worth the....very large number of hours spent getting them right. I think the baffle is 16mm thick, so it needed a lot of shaping to fit under the trims.
Edited by GTSBoy
  • Like 2
@GTSBoy very nicely done, you also have too much time LOL.
My old white R33 had Focal 165K2 and I sandwiched 2x 16mm MDF sheets together and made something similar followed by painting them both in sound deadening. Door proceeded to get 2x layers of eDead (Dynamat knock off at the time).
This car, the fronts have had the stock plastic mounts attacked with a Dremel lol. I think I might get in touch with @Fhrx (hope you're still around Marty) to do my front stage and make a nice slim enclosure for a sub in the boot that also covers up all the SSR shit and surge tank lines.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
