35 minutes ago, Murray_Calavera said:
What's the news?
The ic7 will be firmware updated to allow 2-way CAN communication allowing additional inputs for the ECU. It will also be a master device now, so I believe it can act as a controller for the PDM. You can also customise logos etc.
  • Like 2
Pretty much no need for an I/O expanded if you have a dash.
Also, there may be a new Haltech dash coming in the future, I hope they update the housing lol.
That's the only reason why I didn't buy an IC-7, I know it's silly, sure it's ugly but the car itself is pretty ugly too LOL.
Yeah, I think they are bringing out a bigger display. I think a 10”??
the ability to programme the buttons on the display is pretty good too.
One can hope, if not I'll just get an IC-7 and stop sooking.
Loaded up the latest firmware, oh wow... went for a drive and it's like I've setup Alpha-N and MAP compensation. I thought the transient table I built was good, but wow... this just brought it to another level.
@R3N3 this is how I make the car brap lol.. sounds better than rotational idle
Nice little timing hole lol
And for the idle control you want it to not much between -50 ~ -100 RPM
Awesome! I will compare the sound. I ended up dialling in the launch and rotational idle 100% many bangs and flames were had. Although I’m a little worried about my stock oil pump gears…
  • Haha 1
1 minute ago, Dose Pipe Sutututu said:
Didn't you want to build a new motor? LOL.
Haha, true! The plan is to switch out a working motor with another working and better motor…
Last time @admS15 used his launch control, he lost a turbine LOL.
On 08/10/2023 at 1:38 PM, Dose Pipe Sutututu said:
Washed the shit box, forth wash since the start of 2021 when the respray was done.
As much as you like to complain about it, your car is a looker! Is this photo with new tints? Which ones did you end up going with?
It's on my list of things to do, though not at the top. Being able to see nothing at all out of the windows when it's dark and wet outside gets old very quickly.
I work in IT, complaining is a prerequisite LOL.
I went with a legal 35% tint, it's some ceramic bullshit (apparently good?). Got it done by Tint a Car in Moorebank.
  • Like 1
Haha, fair enough. Yeah ceramic is meant to be better with keeping off heat. Or so I learned doing all of five minutes of research.
But for some reason the extra photos you included in your post that show the new tint don't load.
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
    • Cool, I’m just down Sydney today. Not much time to get online.
    • Yep, all good ~ the spare AC fan here, I think has a dead armature segment (I didn't pull it apart to verify, as there's plenty of AC fans out there that can be fitted to the R31)...I'll get some pics of the exterior trim pieces...
