14 hours ago, Dose Pipe Sutututu said:
This comment has kept me up at night (amongst other reasons).
Funny enough, old GReddy plenum instructions just stated to plumb it into the fitting I had initially chosen.
I was also thinking hard about it as there is no pressure differential under the head gasket.
I ran a hard line across the front of the block and into a 90deg in the bottom of the manifold.
I wanted to go straight into the manifold where the elbow to the radiator outlet is, but I couldn't make anything that that was easily removable with the timing belt covers on.
I'm not 100% happy with the turbo end so I'll redo it before the front goes on.
  • Like 1
@fletch rb30 looks good! If my motor wasn't in the car, or the timing belt was off, I would be redoing the hardline to run it in front of the motor like what you've done.
Another idea is to return it back to the thermostats housing, similar to how it's done on the RB26, could that be an option?
In a previous incarnation I ran it round the back and into the thermostat inlet teed into the heater return. It worked fine, but when I turned it off, I could hear it boiling and slugging etc.
I figured it would be good to try and get it towards the radiator and let convection cool it until it was the dame temp as everything else.
I thought rb26 had a nipple on the top hose fitting where both the turbo water returns went. I have seen people delete that with a rd28 outlet and run the turbo outlet straight to the radiator top tank.
  • Like 1
Seems this is common on RB26
However makes more sense on the lower hose as it's cooler and will promote flow
And correction to my previous post about it being the RB26 thermostat, we can see that it's not in this photo
Now with fluid, 1bar test again. Pretty much below the pressure of a running system anyway, when you think about it, an OEM cap is 0.9bar.
15 minutes ago, No Crust Racing said:
Look at mr big shot with his branded pressure tester while I'm over here with my blow mould case ebay job...
Not mine, borrowed it :)
  • Haha 1
If I could turn back time, I would tell my old self to strip the car when the last motor blew and go save for a bit more a M3 instead of blowing money respraying and building a new motor.
Stupid things you do when you're not thinking long term...
I run the turbo water return along the rail and into the tank of the radiator with a -6AN line. My radiator is a dual pass cross flow so it was easy to weld the fitting straight on there.
Also, it's a race car so zero f**ks given about heaters and so on.
In relation to buying an M3/GT3 instead of tipping money into an old shitbox, tell me about it! I do sort of worry that a modern super car would be too perfect so I keep digging a deeper hole with my R32 and stick my head in it!
  • Like 1
Lol... We are not normal.
If space, and finances weren't an issue, I would love to have both, a M3 and this R33 shit box. But the Matrix does not allow it.
Working from home, means clean filtered water, access to beer and opportunity to refresh the twin water filter in the kitchen.
I keep hearing Australian tap water is clean, good dis dat. Anyhow, these filters are less than 11 months old.
LHS is a 1 micron filter, RHS is a 0.5 micron, ignoring the RHS, the LHS one tells a very different story about how "clean" our tap water is.
  • Sad 1
"Clean" as in "low enough counts of coliform bacteria and other gut twisting nasties that you can drink it without fear of shitting your insides out afterwards.
Not necessarily "clean" as in "freshly melted off a virgin glacier that last saw open atmosphere sometime before the mammoths went extinct".
Adelaide has some of the "cleanest" water in Australia. By this I mean that our water traditionally made it to our reservoirs by trickling across cow paddocks and so the old engineers at the E&WS had to learn how to clean it good to make it safe to drink. Doesn't mean that it wasn't nasty tasting, hard as rocks and chock to the brim with chlorine.
By contrast, Sydney had it so good with water that original fell on pristine mountainsides that their water supply engineers never learnt how to scrub water properly and so for years and years there were Giardia outbreaks and the like, that only stopped when some E&WS engineers went across and taught them how to do it.
In some places, like Bunbury in SW WA, the water falls from the sky nearly every day, but still somehow manages to taste like it was filtered through some rusty steel wool. Safe to drink though - just nasty tasting.
  • Like 2
Yeah, we have a few filters too, the main one is the 4 stage I use for the aquarium water (yes, it gets better water than the people in the house). I'm always shocked when doing my 12 monthly replacements.
  • Like 1
I didn't expect it to be this dirty though!
That I don't disagree, but it's the dirty and old pipe work it needs to travel though before reaching the tap for consumption.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
