Dose's Sometimes DIY and Pay Someone Home & Boat Improvement Thread
1 hour ago, GTSBoy said:
......By contrast, Sydney had it so good with water that original fell on pristine mountainsides that their water supply engineers never learnt how to scrub water properly and so for years and years there were Giardia outbreaks and the like, that only stopped when some E&WS engineers went across and taught them how to do it.....
our Wombats and Kangaroos wee in that river.
  • Haha 4
So I decided that I wasn't happy with how I originally wrapped the loom with fleece tape. I didn't factor in the new intake manifold/plenum so it always sat a bit funny.
Yep, I decided to unwrap it and redo how the wires would branch out. Added in a light twist too, here's hoping I didn't snap any 30 year old wiring because FML if I did.
Took a few more photos of the shit box too, needed it for Enthusiast Insurance as they wanted photos to justify why my agreed value was above market by a fair amount.
  • Like 7
You should see what the fish do in it! 😮
Somehow I managed to snap off the coolant sensor wiring when I pulled through the loom, then at the same time managed to also snap off the coolant dash sensor plug too.
To make things even more fun, I thought it would be nice to recrimp the ring terminals for the earths, to only find out the terminals I had at home were too small for a M6 bolt to go through.
Anyhow, managed to fixed the lot yesterday during lunch, installed the e-throttle. Slow and steady, but we are getting there.
Next is to tidy up the harness with some trusty race zip ties and then install the starter.
  • Like 8
2 hours ago, Dose Pipe Sutututu said:
@Kinkstaah
And yes, the exhaust is so quiet you just hear plenty of injector noise and solid lifter noise.
Oh you sweet summer child. This is a quiet engine bay and a booming exhaust where I'm from lol. Sometimes I do miss the RB.
    • I bought the car like this, but the previous owner installed a on/off switch on the dash to turn on the AC compressor. I believe this switch is wired to the engine bays fuse panel. When i switch the AC compressor on, i feel it dragging the engine and it makes a grinding noise. My question is, should i have the AC compressor rebuilt? is that a possibility? or should i buy a new one?
    • Anytime I still have a small amount of new oil left after an oil change on one of our cars, I dump it into a container. It's a concoction of different weights that I like to believe evens out to a 10W-30. I do an oil change every year on both my tractor and mower using that oil. Mower is at least 12 years old, and my tractor is about 5 and sat 2 weeks under 10 feet of water. Both still run great!
    • Depends on your hp target/if you want to max your turbo, in my experience a twin scroll housing will spool like a much smaller single scroll housing, with little to no loss of peak hp. If you want quickest spool, Pulsar sells 0.85 t4 ts housing for g30 and g35 at less than half price of Garrett's housing.
    • Ring & pinions are not interchangeable between long and short nose. Pinion is longer in a long nose diff. Cheers.
    • I believe it is a r33 throttle body form any rb25det that will work, so I ordered one of these up, we will see.
