4 hours ago, r32-25t said:
Did you get the 230mm version?
I’ve got the solid center version and it’s a dream to drive
Yeah same as yours, however just sprung centre.
Trying to prolong the box going KAPOW as long as possible lol
  • Like 1
On 11/26/2024 at 10:18 PM, Dose Pipe Sutututu said:
Been needing a new clutch for a while, but holding off because of life tingz and adulting.
But... Being of Asian descent, I can't pass on a good sale, especially everyone else is selling it for $2k+ (JJR has it for $1799).
Really on the fence on this one, because the unsprung version of this is $1281 via Shitbox (Sparesbox) and the sprung version is quite a bit more (no idea why Shitbox doesn't offer them).
Ending up just sending it and getting the twin sprung organic. Mainly because I wanted the car to be nice to drive and didn't want to make it more of a shitbox than it already is.
I used to daily mine with a 6 puck button clutch. It drove (to me) like a factory clutch. Roll it off the mark all like normal, no jerking, no bucking.
Hilariously no one else could drive it without dialling up about 3,000rpm and chirping the tyres off the mark, or stalling it.
It's all about getting used to it.
  • Like 1
Haha yep, everyone stalls mine. Even catches me off guard when I'm trying to reverse up my driveway into the driveway with a decline.
Hoping the twin plate sprung organic is a bit more forgiving for my old and tired body/legs/pelvis.
  • Like 1
Fark this... mental health day it is tomorrow.
Booked Luddenham lol
Is the clutch fked? yep
Do I need to fix that in tank venturi? yep
Will I do any of the above? No
  • Like 1
  • Haha 1
Yeah boiiiiiii
PB the karnt, then lost an IC clamp. Was also warned about go sideways 😂
He said he understands the track is hot and tyres let go in the heat.
Called it a day 4th session, came on the throttle on Lap 2 and lost boost. No idea where the passenger side IC Bluetoothed to, and it was getting quite hot so called it quits.
Waited for the other boys then we ended up at the pub for 3 hours lol.
My mate in the R33 shit box managed a 59s on his first track experience at Luddenham.
  • Like 7
6 hours ago, Milkmun said:
How much work to get you in the 55s? Or just more seat time?
I think just better tyres, I'm just on Hankook RS-4 tyres at the moment, which aren't really meant for the track.
Also, been mucking around with my suspension for sometime now and I'm really happy bow neutral it is. Car doesn't want to just oversteer or understeer like it did years ago.
Time to put on proper tyres one day and see what the shit box can do at SMSP, One Raceway and Luddenham again.
  • Like 1
Yeah, you'll never get a reasonable time without spending on tyres, they ware worth more than all the other mods put together for lap times.
How's the garmin going? It is difficult to get data logging into the new car (because must retain standard ECU for tuning which can't do lap logging so need separate systems nekmennit), was thinking about using one of those in the meantime
It's great, fantastic bit of kit for the novice like me.
One thing it doesn't do, as @No Crust Racing pointed out before, is capture CANbus data. Would be great to get additional data from the car to overlay.
I'll download the video from my 56s for a laugh soon.
  • Like 1
yeah basic OBD data would be nice, and cheap electronically to add, might be coming in future.
unfortunately in nissan at least, only a small subset is on the OBD can and all the interesting stuff like boost or oil pressure is on a proprietary CAN
  • Like 1
It's easy to tap to the other CAN networks, and in addition, most of the stuff you'd want could be obtained by querying the data over UDS on the network available on the OBD2 port. That said, it's much nicer to just listen on the appropriate network to data that's being streamed rather than querying in steps using OBD2 or UDS.
10 hours ago, niZmO_Man said:
what are you going to get?
I think depending how much left over cash I have after all the kids and wife (daycare, extra curriculum activities, toys, and whatever they drain from my account, wife's spending, etc.) I might go for the Advan A052 OR if the bank account says no, then Nankang CR-S.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
