8 minutes ago, Dose Pipe Sutututu said:
(Noting I'm Asian, I'm not a great driver and our DNA has wired us propel either Toyota Camrys or Tesla Shitboxes).
Brother, nope, I've watched a "documentary" that proves otherwise
  • Like 1
  • Haha 2
That’s racist
  • Haha 3
20 minutes ago, No Crust Racing said:
Don't you have a Camry to crash somewhere?
this page is the best
https://www.facebook.com/camryfail
examples:
  • Haha 1
On 12/8/2024 at 10:51 AM, Dose Pipe Sutututu said:
Not specifically the revamp Toyos.
In the past I've used Nitto NT01s, which were essentially the same compound as R888 with a different pattern (that's what the internetz said, so just be facts). I did like the NT01, progressive fade, didn't go from grip to 0 grip in a split second.
If you look at the serious street/track guys, most are either on Cup 2, A052, A050, AD09, CR-S or AR-1.
Go the CRS, cheaper than the A052 and same if not better 1 lap performance when suspension is dialled for it. If wanting to do back to back laps the A052 and can cool off and go again next lap will be the better option.
I have gone quicker over 1 lap with CRS than the A050 I came from but may be due to getting more seat time.
I am driving CRS on the street lately in different conditions and its going well, a lot better than AR1 in the wet.
11 hours ago, No Crust Racing said:
MMM ok,
I see a bit of praise for RE003s, but CR-S sounding like a better option, seems Nankang wants those to replace the AR-1
AR1 is a race tyre, CRS is a Hill Climb/time attack/Sprint tyre. 2 different things, a slick is on the way too.
The mighty gay mods choice of tyre is proper rubbish for those that actually drive on track not park at bunnings at night.
  • Like 1
9 hours ago, No Crust Racing said:
CR-S decent "budget" option, but still a grand+ for tyres.
No idea what they're like in the wet though.
probably around the $1700-1800 fitted in his sizes.
The ar1 is heaps cheaper.
Get on scumplace I got some A052 295/35/18 for $400 that had done maybe 20-25 hot laps of SMP.
  • Like 1
On 09/12/2024 at 9:03 PM, No Crust Racing said:
People are going faster on CRS than AR1, so there's that 😕
But to be fair, I think people have gone faster on Bob Jane All Rounders than AR1's; particularly if it's wet.
  • Like 1
I managed to win under 2L turbo/4L NA class championship in our club with a single set of AR1s, including several wet rounds, and they were still getting faster end of the season 0_0
For $800 in 255/17 I was very pleased (7yrs ago so adjust for inflation)
Merry Clitmas you dirty cnuts.
24 hours ish in the sous vide at 50°C, then finished it off in the pizza oven at 500°C. Internal temp peaked about 56°C, albeit a bit higher than I wanted however still butter soft.
Don't ever let the mother in law out cook you at family events.
Yes, that plate was bought in Ischia, Italy.
  • Like 5
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
