8 minutes ago, Dose Pipe Sutututu said:
(Noting I'm Asian, I'm not a great driver and our DNA has wired us propel either Toyota Camrys or Tesla Shitboxes).
Brother, nope, I've watched a "documentary" that proves otherwise
  • Like 1
  • Haha 2
That’s racist
  • Haha 3
20 minutes ago, No Crust Racing said:
Don't you have a Camry to crash somewhere?
this page is the best
https://www.facebook.com/camryfail
examples:
  • Haha 1
On 12/8/2024 at 10:51 AM, Dose Pipe Sutututu said:
Not specifically the revamp Toyos.
In the past I've used Nitto NT01s, which were essentially the same compound as R888 with a different pattern (that's what the internetz said, so just be facts). I did like the NT01, progressive fade, didn't go from grip to 0 grip in a split second.
If you look at the serious street/track guys, most are either on Cup 2, A052, A050, AD09, CR-S or AR-1.
Go the CRS, cheaper than the A052 and same if not better 1 lap performance when suspension is dialled for it. If wanting to do back to back laps the A052 and can cool off and go again next lap will be the better option.
I have gone quicker over 1 lap with CRS than the A050 I came from but may be due to getting more seat time.
I am driving CRS on the street lately in different conditions and its going well, a lot better than AR1 in the wet.
11 hours ago, No Crust Racing said:
MMM ok,
I see a bit of praise for RE003s, but CR-S sounding like a better option, seems Nankang wants those to replace the AR-1
AR1 is a race tyre, CRS is a Hill Climb/time attack/Sprint tyre. 2 different things, a slick is on the way too.
The mighty gay mods choice of tyre is proper rubbish for those that actually drive on track not park at bunnings at night.
  • Like 1
9 hours ago, No Crust Racing said:
CR-S decent "budget" option, but still a grand+ for tyres.
No idea what they're like in the wet though.
probably around the $1700-1800 fitted in his sizes.
The ar1 is heaps cheaper.
Get on scumplace I got some A052 295/35/18 for $400 that had done maybe 20-25 hot laps of SMP.
  • Like 1
On 09/12/2024 at 9:03 PM, No Crust Racing said:
People are going faster on CRS than AR1, so there's that 😕
But to be fair, I think people have gone faster on Bob Jane All Rounders than AR1's; particularly if it's wet.
  • Like 1
I managed to win under 2L turbo/4L NA class championship in our club with a single set of AR1s, including several wet rounds, and they were still getting faster end of the season 0_0
For $800 in 255/17 I was very pleased (7yrs ago so adjust for inflation)
Merry Clitmas you dirty cnuts.
24 hours ish in the sous vide at 50°C, then finished it off in the pizza oven at 500°C. Internal temp peaked about 56°C, albeit a bit higher than I wanted however still butter soft.
Don't ever let the mother in law out cook you at family events.
Yes, that plate was bought in Ischia, Italy.
  • Like 4
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
