Baffled Sump by the look of it? I always liked the prospect of the HOR extended sump but I read its a pain in the ass and can only be fitted with the engine out. Lucky you're already there ;)
Baffled but not gated, feeling a bit poor haha.. Yeah you "could" do it motor in but at that rate you might as well take the motor out.
Some progress tonight, I removed the crank. Some scoring on the bearings so might change all of them too :(
I was hoping on the conrod bearings needed changing but YOLO right? I still want to retain the standard NEO rods and NEO pistons because they said not to let the Nissan out *ahem* @GTSBoy, @Piggaz. Nissan hasn't been let out lol.
Oh hai! Looks the goods, sump was modified to suit the AWD motor going RED as the pick up sits more forward. Test fitting was spot on, I like very much - great success.
Off to the machinist it goes, the silly crank.
43 minutes ago, admS15 said:
Nissan is well and truly out now brah. You've contaminated it with Sydney air. Should be alright though. #RBLIFE4EVA
Still stock!!!
Crank at shop, but their machinist has buggered off overseas for 4x weeks!
Thinking if I should do connecting rod bolts too lol.
Still stock motor :)
  • Like 1
Are stock bolts capable of 400rwkw?
If no, then replace.
Given the driving style I'd worry more about balance/harmonics/oil pump strength etc.
Unless the rod bolts are a known weak point?
Got a good balancer for it?
1 hour ago, Dose Pipe Sutututu said:
derno, Matt Wooten & TIm Burt don't seem to have issues with stock oil pump, stock rod/bolts
Soooooo why did you pull it apart if these guys have been trucking along for years with the stock setup?
just to install the Spool oil pump gears and to install a new head gasket - that was it :)
May have gotten a tiny bit carried away with the headwork but that's just it.. everything else is just pretty stock
  • Like 1
Actually had free time for a change, which I rarely do.. so decided to do some work on the siet bok rust bucket.
I always has an issue where the camber kept changing every track day and I had a feeling the OEM camber bolts were moving so I decided to deleted the bastard with this GKtech camber lock out kit.
On removing the OEM camber bolts it was evident the machined groove and offset washer weren't working correctly, most likely slipping when I'm smashing into ripple strips.
Man 60% of yhe arms are Hardrace lol.. bastard should sponsor me!
  • Like 2
Yeah cnuts!
Removing those stupid machined screws are not fun, used those impact/hammer screw drivers and a bit of heat. I bashed the shit out of the pump like Pacquiao vs Horn and eventually all of them came out.
Yay, it's not broken but who cares we are going billet!
Result? Billet oil pump gears, hectics bro - can smash limiter all day like a JZ now!
  • Like 3
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
