Dug up some old data prior to the motor blowing up. Managed to crack the 200km/h barrier down the main straight of Wakefield Park - this back up the car was making some decent power till it spat ring lands (we all knew it was going to happen).
Machinist should be back soon from his last minute holiday and I'll get the crank back then it's party time (maybe).
I have a track day I'm running with Yez Racing guys so would be nice to have the car running. Let's see!
  • Like 1
  • 1 month later...
3x months later I've gotten my crank back, what an adventure with that shop. Not to mention they decided to charge me more as well, what arseholes.
Anyhow that aside, I've gotten my cam covers powder coated black because stealth is best.
  • Like 3
  • 3 weeks later...
18 minutes ago, GTofuS-T said:
Size?
Are they much lighter?
Went yalla habibi spec, 18x9.5 +22. Has some homosex 245 wide tyres, once the car is running again OR when I decide to put a motor and gearbox into it I will get the guards cut/reshaped to allow 265 semis to fit under the guards and look stock. No gay stretch no gay camber.
And funny enough, the Rays 57S aka Gram Lights are indeed lighter than the OEM GT-R wheels.
15 minutes ago, admS15 said:
Much betterer
Thank you sir, need to make the car look good before it runs lol
  • Like 1
Pull your finger out and get cracking son. FYI, i have 18 x 9 +22 all round with 265/35. Fit good. Rear guards are rolled a bit, running -2 camber and front has unrolled +20mm fenders. With 265 on 9 inch there is about 5-7mm clearance to the upright.
Decided the block should be painted black, so it got painted black.
Also the stock pistons were given a clean, looking good.
So I decided to get new rings, new ACL race bearings, new ARP rod bolts, new ARP 2000 mains, Spool crank collar, Spool Billet N1 oil pump gears installed and lastly the OEM water/oil heat exchanger was deleted.
Motor is still stock lol.
Special thanks goes to Matt at Redsun Motorsport & Mechanical for dealing with my bullshit and also pointing out some cock ups with a previous shop that did my crank collar install.
  • Like 6
Spent part of Sunday going through my collection of nuts and bolts from last year. Not fun, also turns out the service manual doesn't tell you of bolt lengths to use lol.
Modified RWD pickup installed, one day this motor could go into a GTR lol.. 0.1L smaller but higher compression, has VCT, billet oil pump gears so it won't go bang!
Installed water pump, ancillary bracket as well as the alternator. Whilst installing the water pump with gasket maker I then rummaged through the box and found a gasket for it lol.. too bad so sad.
Another hiccup was that the Stagea engine mount brackets/arms are no good in the R33 so will need to source RWD ones. Then as I was installing the knock sensors followed by the OEM oil pressure sensor - I realised the NEO uses a different one so derp.. need a R33 one.
  • Like 3
13 hours ago, ActionDan said:
Worth redoing the water pump or you confident in the gasket maker?
Nissan manual advises to use gasket maker, so should be on point.
I really hate putting it together.
I have never used anything but gasket maker. The gasket looks like a piece of a4 paper cut roughly into the shape of a dick anyway, would much prefer liquid gasket
  • Haha 1
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
