On 24/02/2022 at 12:49 PM, Dose Pipe Sutututu said:
Walked in, walked out $550 poorer.
I now have new bonnet/hood insulation 😂
Amayama couldn't source one, Kudos couldn't either, even tried EFI Solutions but somehow Skyline Spares could so yeah, sent it and bought it.
This is more expensive than a coacine addiction.
Different than 33 GTR right ? Also try JP car parts for stuff. They've sourced things for me Amayama hasn't been able to get or said was discontinued.
  • Like 1
It is a bit different, however both are same same in what they do and how they mount.
I haven't even opened the box yet, just added to my parts museum to install one day :D
I must admit, I didn't really try very hard to locate it - but thanks for the tip with JP Car Parts, will try them next time I need more replacement parts for the shit box.
One sensor issues at a time, worked out why my oil temp was reading out of whack.
Turns out when you run a temperature sensors on a SP Input instead of an AV Input the internal pull up is 10k Ohms not 1k Ohms. This means the standard calibration table cannot be used and needs to be offset.
Haltech did supply me a new calibration table to suit, however advised that the resolution will be reduced.
To fix this small issue, I decided to move the EMAP input to SPI2 and move the Oil Temp input to AVI10 (didn't do this initially as I used the OEM power steering input and pinned it to the OEM AFM and it all sat on the main 24 pins connector).
Instead of cutting, crimping and shrinking I decided to swap it on the ECU side AMP plugs. How good are these AMP plugs? No need for any fancy thin depin tools, etc.? Anyhow was a 5 minute job and hello full range and full resolution oil temperature.
  • Like 1
Actually, be really careful with depinning those AMP connectors....I find them an absolute arsehole to work with. The tabs on the locking cap break easily then you are left with a connector that is almost impossible to seat back in properly locked. I ended up buy 2 new ones out of the US (Haltech would not supply) for a fortune.
Also, they are very fiddly with seating the pins at the right depth, initially is OK but if you repin something you have to make sure every wire is still seated properly as they can back out. Pretty much every other style of connector I've worked with is easier, except for those POS pull through ones like in the pressure senders.
*edit* cancel the locking clip rant, that is a different type of AMP lock they used on the smartwire. The one in your pic looks much better (maybe they redesigned after issues)
Edited by Duncan
clarification
  • Like 1
You're probably thinking of this style of Tyco connectors, these are a complete cnut to get right as per your experiences.
The other end to the plug and play adaptor uses these and yes, I've ended up just wiring direct to ECU instead and bypassing them as they're a cnut to work with 😂
yeah those are have a crappy lock too, but I meant these ones
Same pins and similar body to what you have but the red piece does the locking and is brittle. PITA.
Deutsch is the ones when you have a choice, even their big multi pin connectors are great to work with. Expensive tho.
  • Sad 1
I know that plug, great to build once and never look at again lol.
Yes I also hate, and have replaced the entire auxiliary connector before. Depinning it a nightmare.
Cutting and recrimping is easier, that's saying something!
On 28/02/2022 at 8:32 AM, ActionDan said:
I thought you were coming down to wire and tune????
I barely have time to sleep these days, let alone work on race cars that are 2000km away lol
Found a few minutes spare today, turns out they sold me a GT-R one.
Good enough, just 1x clip hole doesn't like up. I have the option of punching a new hole OR drilling one. Still a bit undecided on what path to take but I'll do it one year.
  • Like 1
On 05/03/2022 at 8:11 AM, WantGTR said:
GTR DNA
thats it boys. pack it up.
Nah failed at that one, has a twin scroll single turbo and has VCT.
Needs no VCT, twin turbos for the lags.
  • Like 1
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
