robbo_rb180 Posted March 27, 2022 Share Posted March 27, 2022 On 3/27/2022 at 1:43 PM, MBS206 said: And I was only saying on Friday I wanted a wiring diagram for the window switches, as I want to see how they do it from the factory before I get a double throw switch and 2 relays per window and make my own old school circuit to run them! easy to use 2 switches & 1 relay. 12v+ to each side opposing & same with negative with centre to window motors Enjoy my paint wiring diagram 1 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7962593 Share on other sites More sharing options...
robbo_rb180 Posted March 27, 2022 Share Posted March 27, 2022 On 3/27/2022 at 7:18 PM, Dose Pipe Sutututu said: Just send it, use a PDM @MBS206 wire it to a canbus keypad and then have soft start etc. People will froth Buy a Nexus and wire everything and do heaps of other stuff. Enough outputs for almost any engine setup Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7962594 Share on other sites More sharing options...
MBS206 Posted March 27, 2022 Share Posted March 27, 2022 On 3/27/2022 at 7:31 PM, robbo_rb180 said: easy to use 2 switches & 1 relay. 12v+ to each side opposing & same with negative with centre to window motors Enjoy my paint wiring diagram I was thinking of just having two switches and no relay. Need to measure peak current on a stalled motor window. From what i can picture in your setup, i cant see how youre using the relay to remove high current from the switch, your switch has to be in the same side of the circuit as the motor. Nexxus, ha ha ha ha ha, man, Id love one, but i dont have that coin. Id pay for the roll cage before a Nexxus. That being said, part of a project I have at work involves a programmable IO module. Its just slightly lower in the order than another project right now. Once done Ill be programming it for my own exact purpose, including a CAN keypad for a lot lower cost than I can purchase a Nexxus for. Do love the Haltech gear though, want Nexxus, Keypad, and Dash. 2 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7962595 Share on other sites More sharing options...
robbo_rb180 Posted March 28, 2022 Share Posted March 28, 2022 I was running a relay so had direct feed from battery without voltage drop can wire 2 relays & low current through switch 2 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7962667 Share on other sites More sharing options...
MBS206 Posted March 28, 2022 Share Posted March 28, 2022 On 3/28/2022 at 9:49 PM, robbo_rb180 said: I was running a relay so had direct feed from battery without voltage drop can wire 2 relays & low current through switch Yeah this is wjat i was looking at with dual relay and a switch per window. Depending on the current, if I can find a good mometary DPDT switch that will take high current, ill use it direct, with the relay just for switching windows off when ignition power is off. From what ive seen, lots of manufactufers do it, hence the lots of arcing amd carbon burn in switches over time. 1 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7962675 Share on other sites More sharing options...
Dose Pipe Sutututu Posted April 3, 2022 Author Share Posted April 3, 2022 Very potato photo, just took it as I was leaving as my mate asked where I was heading in the R33. Left about 8am and took a very extended drive to Meat Emporium to pick up wagyu lololol. Night before pulled out the laptop and set 1bar of boost, 17 degrees of timing mid range and 19 up top. Safe as shit and closed loop O2 to take care of the rest. Gave it many jabs to 8k rpm (limiter is 8500rpm). Must say, it's very linear in terms of power, where as before with smaller cams and the OEM intake manifold/plenum you could feel a big surge of torque coming on. Probably put it on the dyno soon, when I have time. Alex from Birrong has been asking me when I'm bringing it in, I'm sure he's keen too (as the choice of parts isn't what he's used to putting together). 5 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7962832 Share on other sites More sharing options...
Dose Pipe Sutututu Posted April 9, 2022 Author Share Posted April 9, 2022 Some billet brace goodness 😂 This is the only billet brace I can afford. Needed a better battery clamp solution as the flimsy clamp from Supercheap wasn't holding the battery in place, especially after cutting off one side of the battery guide on the tray to fit a larger battery. 1 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7962989 Share on other sites More sharing options...
MBS206 Posted April 10, 2022 Share Posted April 10, 2022 On 4/4/2022 at 8:20 AM, Dose Pipe Sutututu said: Very potato photo, just took it as I was leaving as my mate asked where I was heading in the R33. Left about 8am and took a very extended drive to Meat Emporium to pick up wagyu lololol. Night before pulled out the laptop and set 1bar of boost, 17 degrees of timing mid range and 19 up top. Safe as shit and closed loop O2 to take care of the rest. Gave it many jabs to 8k rpm (limiter is 8500rpm). Must say, it's very linear in terms of power, where as before with smaller cams and the OEM intake manifold/plenum you could feel a big surge of torque coming on. Probably put it on the dyno soon, when I have time. Alex from Birrong has been asking me when I'm bringing it in, I'm sure he's keen too (as the choice of parts isn't what he's used to putting together). Bit more timing down low once tuned and youll get the surge back years ayearsreduced timing on my 25/30 when it was first put in, as it wasnt yet tuned, may have set it slightly low at only 15 degrees... high mount got hot while i moved the car from one house to another on a 20 minute freeway drive... and thats how my bonnet lining caught fire... 1 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7963022 Share on other sites More sharing options...
Dose Pipe Sutututu Posted April 10, 2022 Author Share Posted April 10, 2022 Yeah mine shouldn't ignite, manifold is coated, have a turbo beanie and also the dump is wrapped. Has survived 2x track days like this without catching on fire. Just binned a motor instead when the cam snapped due to oil starvation. Should be putting it on the dyno soon, just finding time during the week to tune it has been difficult. Work being aids 😭 Might see if I can convince Birrong to open up on a Saturday 🥲 1 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7963042 Share on other sites More sharing options...
MBS206 Posted April 12, 2022 Share Posted April 12, 2022 On 4/10/2022 at 8:34 PM, Dose Pipe Sutututu said: Yeah mine shouldn't ignite, manifold is coated, have a turbo beanie and also the dump is wrapped. Has survived 2x track days like this without catching on fire. Just binned a motor instead when the cam snapped due to oil starvation. Should be putting it on the dyno soon, just finding time during the week to tune it has been difficult. Work being aids 😭 Might see if I can convince Birrong to open up on a Saturday 🥲 Ha ha sorry i was meaning cruising with low ignition timing (low load area). With all the coating etc should be okay Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7963115 Share on other sites More sharing options...
Dose Pipe Sutututu Posted April 12, 2022 Author Share Posted April 12, 2022 On 12/04/2022 at 12:42 PM, MBS206 said: Ha ha sorry i was meaning cruising with low ignition timing (low load area). With all the coating etc should be okay haha all good, I have like 30~45 degrees of timing on cruise/vac Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7963116 Share on other sites More sharing options...
MBS206 Posted April 12, 2022 Share Posted April 12, 2022 On 4/12/2022 at 12:53 PM, Dose Pipe Sutututu said: haha all good, I have like 30~45 degrees of timing on cruise/vac Oh right! Thatllteach me to skim read, ha ha, thought youd gone 17/19 through it all, ha ha ha Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7963117 Share on other sites More sharing options...
Dose Pipe Sutututu Posted April 12, 2022 Author Share Posted April 12, 2022 On 12/04/2022 at 12:55 PM, MBS206 said: Oh right! Thatllteach me to skim read, ha ha, thought youd gone 17/19 through it all, ha ha ha relax cuzzy, not using a Microguess with 2D tables 1 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7963118 Share on other sites More sharing options...
Dose Pipe Sutututu Posted April 16, 2022 Author Share Posted April 16, 2022 OEM+ achieved, have a bunch of clips and shit plus the cowl to replace soon (all in boxes). Hopefully someone with a M3 LCI, white, DCT, sunroof, sub 50k kms, near stock wants to straight swap me for the R33 😂 8 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7963239 Share on other sites More sharing options...
Kinkstaah Posted April 16, 2022 Share Posted April 16, 2022 Drive it first, then make a decision. Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7963260 Share on other sites More sharing options...
The Bogan Posted April 16, 2022 Share Posted April 16, 2022 On 16/04/2022 at 9:58 PM, Kinkstaah said: Drive it first, then make a decision. Historically, If he drives it there's a 50/50 chance it will break something Which still makes the Skyline more reliable than a BMW Yes, yes, and more reliable than a 20 year old Holden as well Your car is to pretty to swap for a run of the mill BMW that could be mistaken for a Kia from side on Wind the boost down and enjoy for the next 20 years 2 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7963266 Share on other sites More sharing options...
Dose Pipe Sutututu Posted April 17, 2022 Author Share Posted April 17, 2022 On 17/04/2022 at 9:34 AM, mlr said: Historically, If he drives it there's a 50/50 chance it will break something LOL... I seem to break everything I own and drive. Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7963267 Share on other sites More sharing options...
The Bogan Posted April 17, 2022 Share Posted April 17, 2022 On 17/04/2022 at 10:10 AM, Dose Pipe Sutututu said: LOL... I seem to break everything I own and drive. I also have this achievement unlocked Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7963269 Share on other sites More sharing options...
Dose Pipe Sutututu Posted April 17, 2022 Author Share Posted April 17, 2022 On 17/04/2022 at 10:32 AM, mlr said: I also have this achievement unlocked I think that's called being Australian. I've passed the citizenship test then, no deport to Chyna. (I'm actually born ere') 1 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7963270 Share on other sites More sharing options...
Trex Posted April 19, 2022 Share Posted April 19, 2022 On 16/04/2022 at 3:50 PM, Dose Pipe Sutututu said: OEM+ achieved, have a bunch of clips and shit plus the cowl to replace soon (all in boxes). Hopefully someone with a M3 LCI, white, DCT, sunroof, sub 50k kms, near stock wants to straight swap me for the R33 😂 Man this looks amazing! 1 Link to comment https://www.sau.com.au/forums/topic/468064-doses-sometimes-diy-and-pay-someone-home-boat-improvement-thread/page/117/#findComment-7963908 Share on other sites More sharing options...
