37 minutes ago, Dose Pipe Sutututu said:
That's how the NBN is being rolled out lol
lol no, the NBN is being rolled out equivalent to you just saying f**k it and using the cracked o-rings
48 minutes ago, Dose Pipe Sutututu said:
So close yet so far, typical NBNish delivery lol.. Over budget and project schedule blown out of the water.
This is EVERY Government funded project
  • Like 1
  • Haha 2
1 hour ago, iruvyouskyrine said:
Those bolts go at the very back of the head on either side. Do you even RB bro?
No :(
I SR20 more lol...
where exactly????
1 hour ago, Dose Pipe Sutututu said:
are those the cylinder head to block bolts that go on the outside??
That's what I thought they were when I saw the pic. I thought there was one front and one rear though not both at the same end?
Yes correct. 2x M6 bolts
1 at front intake side and 2 at rear either side.
I should note that i never put them back in any of my engines. With RB25's you can't access the front bolt without taking the inlet manifold off which is a shit job which annoys me as i would rather take the inlet manifold off when the head is out of the car.
Yea they didn't go back on my engine either lol
ahhh I installed coppery colours ones back into those holes.. interesting those bolts I took a photo of, I wouldn't' think they would fit as they're wider than the golden/copper ones I used from the R33 motor.
mad, no fear - didn't fk up
Update but no photos (taking inspiration from @luke gtr lol).
Removed R33 plenum, installed bottom half of R34 plenum.
Now awaiting 1550cc Bosch injectors and a Plazmaman rail. The initial plan was to use the 875cc Siemen DEKA V I had from my old motor but anticipating the power this motor will make there's no way those injectors would cut it, even if I ran 4 bar base pressure.
Been trying to order parts again from Andrew @kudos.motorsports but he isn't replying to my emails :(
Update but no photos (taking inspiration from [mention=37584]luke gtr[/mention] lol).
Been trying to order parts again from Andrew [mention=1172]kudos.motorsports[/mention] but he isn't replying to my emails [emoji20]
Nawww, thanks brosef.
1 hour ago, ActionDan said:
Side feed in that boat anchor engine aren't they?
yeah nah cuz.. I had top feeds in there under the stock plenum before they were even mainstream :)
http://www.trak-life.com/diy-converting-top-feed-injectors-r33-gts-t-skyline-rb25det/
Yah... stainless internals, not modified by any laser cutter/mill/bench grinder/side cutters
US guys usually refer to them as Siemens DEKA V 80lb
I hate modified injectors, those "Bosch 1250cc" are milled.
    • I know that smallbox is not great but as i said it will be for a limited time and iam not going to get crazy. But thanks...i just want to know if i can use that clutch and not have "problems"
    • No no. The Audi boost controller was made from a Norgren (or equivalent) 1/4" pneumatics pressure regulator, a similar (looking) relief valve (to create the "gated" function to keep the boost off the actuator until wanted) and a check valve plumbed in parallel with those two, to relieve the boost back out of the wastegate line after the boost event was over. It was the inclusion of that check valve, used sort of "backwards" as a relief valve, that was the stroke of genius that made the rest of it work nice. The only reason I stoped using it was because it was like any other manual/pneumatic boost controller - it's settings changed from season to season. The Profec is much more consistent winter to summer.
    • A couple of months of gentle driving will be fine. There is a risk that you will kill it. A heavy workout will probably kill 3rd gear. Continued use will wreck the input shaft bearing.
    • That's because R34 RB25DET is a pull clutch gearbox. I have that clutch, behind 25Neo, in front of R33 gearbox. I have brand new R34 turbo gearbox, in a box (cardboard) in the shed right now, and it will be getting used with the same engine and clutch, because I also have, in a much smaller box next to it, the front plate to convert the new box to push clutch.
    • Are you planning to ever come on boost with the RB25DET? The torque of the motor alone will break the little box. It's not a matter of if, it's when.
