4 hours ago, Duncan said:
I'm surprised you can hear a properly tensioned timing belt over the fan and injectors, gates or not. I run the gates one in the race car and can't hear it at all. Obviously they would get noisier between the belt and idler/tensioner bearings if over tensioned
You can only hear the difference with the bonnet up or head in the engine bay, can't tell from the driver's seat of the car. In engine bay though they are definitely noticeable as being whirry.
Fk I hate this car... Was trying to figure out why the stupid ABS wasn't working, even though a new relay went in.
Worked out how to put the ABS unit into diagnostic mode and it came up with code 26, LHS wheel speed sensor short circuit.
So sure, let's take off the sensor, give it a clean and trace the wiring back....
FML... Found a molten pile of loom lol... When the motor and bay was stripped and put back together, the loom was run via the OEM location and points. This is incredibly close to where my the gate is. Normal street use, (drag use which it never sees) the loom would have been fine, but on the track it was game over.
Explains why the ABS and tacho all died within hours of each other lol.
Anyhow, wasted 3 hours stripping it back, crimping on new wires, heat shrinking, etc. Will fleece tape the piece of shit and route the loom differently to avoid this same shit storm again.
Buy a Nissan and mod it they reckon 🥲
  • Like 1
6 minutes ago, r32-25t said:
This is the reason I ran my loom through the wheel arch when I went single
Initially I had the loom running high up, against the strut tower where the OEM PS reservoir is.
When the Birrong guys put together the engine bay, and dropped the new motor in they ran the loom in the OEM location with clips and all (not wrong or anything, also probably for them there's no issue too, as most of their customers are drag racers).
The electrical issues only presented themselves after a track day at Luddenham where the loom was exposed to high heat for 10 or more minutes at a time, instead of a whole 10 to 12 seconds.
8 minutes ago, Murray_Calavera said:
Would you consider remaking that section of harness with Tefzel wire? Could even use high temp fiberglass sheathing for added sexiness.
I want a modern fast car, but my autistic brain will end up with a brand new loom lol.
Like how I said I will never need a built motor or more than 350kW.
  • Haha 2
Like how I say every time I get a new car or bike that "I'm keeping this stock", or my other classic of "while we're in there"
It's a disease, and modifications are the cure
  • Like 1
  • Haha 2
2 minutes ago, r32-25t said:
I reckon fixing your f**k ups would be cheaper then fixing bmws f**k ups
Go wash your potty mouth out with soap.
BMW would be superb, it will be stock and I will enjoy my life not constantly fixing shit.
  • Haha 2
Is that because you’ll be paying out your ass for bmw to fix it?
  • Haha 1
Whether it is a highly modified car, or a standard BMW, you will always need a 2nd car or motorbike to get around in/on
Don't BMW give OPAL card credits when you buy a new one anyway?
  • Haha 2
I've got the missus' Tiguan for that, although warranty runs out next July lol... Might be scary driving around in a VW without warranty.
  • Haha 1
No scarier than driving a BMW still under warranty
Buy one of these if you want a BMW
Classics
https://www.carsales.com.au/cars/details/1979-bmw-6-series-635csi-e24-manual/SSE-AD-5690775?pageSource=details&id=SSE-AD-5690775
https://www.carsales.com.au/cars/details/1989-bmw-3-series-320i-e30-manual/SSE-AD-12906574?pageSource=details&id=SSE-AD-12906574
  • Like 2
Car did not blow up, did find that I dropped the o-ring off the oil cap so there's now a nice oil mist all over the engine bay lol.
Last cruise session, banged the limiter quite a bit in 2nd then spat a PS belt.
Drove car home, I think it was a successful night?
@r32-25t stalker photo below
Managed to do a 2m2s lap on the GP Circuit too inbetween the cruise sessions. Overall, successful day and bumped into a few other SAU members.
Over all I think I hate the car less, it's still a croc of shit but not going to lie did giggle a bit 😂
Btw... Rolling antilag is great fun, everyone needs it.
  • Like 8
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
