More parts came so more parts were installed!
New thermostat housing because my old one looks a bit tired and JHH oil distribution block, decided to remove the RB20 oil housing and went with this sexy bit of gear. Also new sensor installed too.
Yes those are 2x -10AN fittings on the block, no need for homo sandwich plates or shitty relocation kits!
Once again thanks to the team at Kudos Motorsports!
  • Like 1
Nice, I was looking at these, but already went down the path of a shitty relocation kit. so next time.
might just be the photo angle, but looks like that pressure sender will foul the oil line?
That looks awesome but the oil filter housing/cooler has always boggled my mind in these cars.
When you fit the JHH kit, does it come with the side to put the filter on also? Do you need to use a different filter and did you need to change the stud that it mounts to (does the JHH screw on to say an RB25 block if you just remove the stock cooler) I hate to be a pain with all the questions but this does my head in haha.
you will need the oil filter mount, I have an old HKS one lying around so will be using that.. you could easily use a BMC one which would be just as good!
And yes, you would require a new filter as the external oil filter housing I have won't fit the OEM oil filter - generally the Z422 fits :)
and and.. yes the JHH housing bolts on the place where the OEM water/heat exchanger oil filter housing goes on
Haven't done too much since the last update, however all the hose blanking caps now all have hose clamps and I finished swapping the plugs on the injector loom. Decided to not use the conversion plugs and cut off the OEM ones.20171203_212849_HDR.thumb.jpg.4bb21c04fdaae60f6ada8255d17408a9.jpg
So got the blanking cap for the middle feed for the rail and started to install the injectors... Well that really didn't go to plan :(
I needed the o-rings distant to be 55mm at least, I didn't check and mine measures 48mm so no deal!
2 minutes ago, NEO25T said:
Are you going to need a second fuel pump, how much power do you think you could make with the walbro on e85?
Good question, I plan to just get it to a sensible 400kW for now - then once I'm ready might get a surge tank and run dedicated -8an lines to and from the rail :)
  • Like 1
-8 = fuel system bling :)
Bulkier fittings and lines/hoses start to become a packaging/routing problem then.
But I like.
Do you think the walbro will go much past 400kw or is that about it for the pump?
If more fuel supply is required, just for info purposes, lets say the walbro 450 is out of flow at 400kw and you want 450kw can you add a smaller walbro 255 to the system?
Usually i read people using 2x the same pump but would be a bit overkill to use another walbro 450 pump in this case.
Also would you stage the second pump, if so what boost or rpm would you turn it on?
Sorry for all the  questions ?
No need to apologise :)
I'm not entirely sure to be honest, but I will be running a fuel pressure sensor and monitoring that. No more ghetto video recordings of the FPR on the dyno haha.
@SiR_RB with his old car and old setup did over 440kW on a single Wallahbro pump so I'm assuming I should be ok for now. If not surge tank, twin Wallahs and done lol.
Ideally you want matched pumps if not you'll encounter massive flow issues, as one pump is delivering more than the other pump which could possibly lead to smaller one stalling.
  • Thanks 1
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
