Took the shit box out with other shit boxes. Smashed the limiter again in 2nd a few times, I still haz PS belt.
Great success.
  • Like 6
1 hour ago, admS15 said:
No need for an M3 anymore then... Did you chop the Evo?
Evo chopped itself, exhaust manifold cracked.
NA 4G63T lol..
Nah, would still take a F80 LCI M3 if someone is retarded enough to swap.
  • Sad 1
1 hour ago, r32-25t said:
Evo3!! so pretty
He will be at All Jap Day too!
Just needs his manifold fixed before then.
  • Like 1
2 minutes ago, r32-25t said:
At the moment I still don’t have a running car and it’s like 14 weeks away
You're nearly done, what are you on about?
Made a temporary, maybe temporary permanent heatshield for the ABS pump, loom wiring.
Should stop things melting on the circuit after a few laps.
It's a bit ugly, but better than a pile of molten wiring at the track.
If money permits, might use those Real Thermal guys and wrap the gate, housing and dump.
  • Like 3
I'm surprised you think it looks ugly, I think it looks great.
I'm not sure if this would effect how well it works, but painting it black might help it blend in with the background if that's what you'd prefer.
Thanks mate, I might try hitting it with engine enamel black.
Might make blend in a bit more.
Test and Learn tonight, pray to all the 33 gods out there, and the Skyline gods nothing breaks or fails.
  • Like 2
It's alright, good to use the car instead of looking at it.
Will upload my PB lap soon, just trying to see why I can't get any of the telemetry from the VIRB. Probs dropped it a few too many times lol.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
