3 hours ago, SiR_RB said:
That's correct
tuned at jez and ran 140mph ?
About 448kw at 24psi
If my stupid build ever finishes or if I don't rage quit and burn the lot I'm going to try beat that mph :)
If my stupid build ever finishes or if I don't rage quit and burn the lot I'm going to try beat that mph [emoji4]
Cheer up sunshine, you're on the home stretch now. You just gotta keep it together a little longer[emoji12]
26 minutes ago, SiR_RB said:
How far off are you mate
Just need the injectors to fit somehow, plenum on, redo the entire oil system (as the old one was filled with bits of metal) and then slot the lot in.
Honestly over it :(
Man you need to harden up, this has been a small and quick build by comparison to what goes on around here.
Stop being so precious, it will make it easier when it throws a rod on the dyno ;)
Okay so besides the fact I can't seem to get ever so popular 1/2 height with extension injectors on, I decided to bend some left over strips of aluminium to fit my obsessively large 25 row Setrab oil cooler than cost as much as my kidney.
Will redo the brackets again once I'm happy with fitment.
(Yes that's a bit of cable ties on the rear end lol)
20171216_185644_HDR.thumb.jpg.1cd07c9a1883327072ee5a83fb601876.jpg20171216_185620_HDR.thumb.jpg.5fe58dc3aa4ff0043838c1b9467f152f.jpg
My injector woes in a thread:
Long story short - don't try and fit 1/2 height injectors to a RB25 NEO intake manifold. Even though they're at the right height using extenders blah blah blah they don't fit. All resellers will tell you they fit, they don't. They are wrong, I am right.
  • Like 1
Serious note, if anyone wants to take my car/motor/tools/spares the lot.. I will trade for a BMW 335i F30 or E90 (must have N55 motor) in auto.
Over it.
BMW must have less than 70 000 km/h
Nearly defeated but as son of immigrants I will never give up that easily :)
Plenum is now a R33 item, new R33 Plazmaman rail and shit fits now. Turbo housing back on too with a welded elbow, no more blowing off silicone hoses.
Not long to go!
  • Like 5
New dip stick, just because lol.
And these engine mounts, was going to get Nismo ones but Phil insisted I get these whilst he ordered a set for his S15. TBH I think they're gay as aids, drove his S15 and could feel engine vibrations through the steering column. But that's a stock bottom, unbalanced S15 so Yeah.
I have urethane mounts on the r34 and the vibration is pretty much unnoticeable after around 500km of driving. Same mounts on a friends evo 6 was a totally different story however.. these will be fine on the Skyline I think
On 31/12/2017 at 4:58 PM, NEO25T said:
How much movement or flex do those mounts have?
Are you going to put both in or just 1 on passenger side
They seem to have "some" flex, I'm skeptical. Run both for now, if they're shit I'm going to send it.... Into the bin.
Hopefully, the RB is somewhat more "balanced" than a tractor motor lol.
Hoping to get the motor in this weekend.
  • Like 1
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
