50 minutes ago, Dose Pipe Sutututu said:
Probably the most quiet mildly powered R33 one has heard, the solid lifters are louder than the exhaust lol
You have no idea the ratio of "Engine and Gearbox Sound relative to Exhaust sound" that are out there, I can raise you tenfold with the symphony of brick-in-washing-machine sounds the LS and T56 make.
This car is mint, and is far more interesting than any stock BMW, and likely a much better car too, not to mention far more rare/street creddy if that is your thing.
  • Like 3
  • Haha 2
29 minutes ago, ActionDan said:
Don't agree, I think he will love it when it happens, it'll only be how much $$ he loses on the 33 that he remembers lol
Dan is correct!
  • Thanks 1
Last night you would see the M cars & Euro cars push into turns later, brake later, etc. They were having fun, albeit there were sheets of water on the track.
Meanwhile all the 90s JDM shit boxes without any stability/traction control etc. were literally cruising around the track. Luckily enough I have working ABS so could brake a bit later than others.
15 minutes ago, Jasoncauser said:
would you take the Beemer on the track? or would it be too precious?
I would take it to the track, think about the amount of money I've spent on my shit box - it's comparable.
Also I would rather push it on the track instead of on the streets or twisty roads, etc.
  • Like 3
I think more seat time you will be close to euro guys.
After talking with some of the QLD time attack guys that went down a few weeks ago it sounds like it's racing for sheep stations down there. The euro cars definitely have the upper hand straight up.
  • Like 2
At Wakefield, on a dry day I was only a few seconds behind them, but once the track conditions are not optimum you can really see the gap widen!
These guys are abusing the stability control, traction, ABS like crazy (I would too).
It's not just safety tech.
Modern chassis are superior all round, what you get in a "road" car these days is akin to what was a race car previously in terms of chassis stiffness, anti-squat geo, king pin inclination bump steer correction etc etc
Suspension kinematics are vastly improved all round, ignoring specific alignment settings like cabmer/castor.
An equally tired 86, even with a bit less power is faster than an S-chassis around a 1min per lap track with both drivers being of roughly equal skill. the 86 chassis is head and shoulders better in every way. It was only when we went to Winton that had a few straights I could use the power of the CA to pick up some cheap lap time.
On anything tight/twisty, the 86s kill S-Chassis and MX5. Just one comparison.
  • Like 3
That pretty much sums it up!
The casual M2 guys at Wakefield before literally just threw on semis, better pads, a tune off their phone, 1/3 of an exhaust system and they're doing 1m5~8s.
Better low/mid-range power for a given capacity/engine config vs the 90s and the ability to put it down and carry it through corners from the factory floor is hard to beat.
  • Like 2
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
