1 hour ago, MBS206 said:
When you say full hard on the rear and soft on the front, what do you mean exactly?
Spring stiffness? Or shock bound / rebound?
My Pedders Extreme suspension only has dampening settings, but the spring rates are excellent for the street, for the dampening settings on the street I currently have them set at 8 clicks from full soft on each end (there is 30 clicks between full soft and full hard), works well for rough Sydney roads
When I got them I started playing around from full soft, and kept clicking over a few weeks of driving to get the compliance I was after
On full soft, if I hit a bump/pothole it would hit the bump stops, on 8 clicks from soft it glides over bumps like a Limo which is what I want for the street
  • Like 1
Shit box now ready, took it to Ian at Porter's Suspension. He knows his Nissan shit boxes very well.
Front we could only get -3.3° after I raised it but that's more than enough for my amateur level of racing.
Rear Ian suggested -1.5° is plenty, based on the tyre contact, said it's not even reaching the edges yet so there's no need to run too much as I'll have traction issues.
Measured up the car, and my broscience and bromeasurements were pretty good. Driver side is about 3mm higher than the passenger side. Slight positive rake as well.
Ian did mention it's rare you actually have people raising their cars for handling because everyone thinks slammed cars handle better but they don't. He said everything the way it is is great.
Ended up with about 7° castor, and 3mm total toe out up front and 2mm toe in at the rear.
Let's see if my rubbish driving can get the lap times down to the  1m50-55s bracket on street tyres.
  • Like 9
Heard a lot of good feedback about that shop
Yeah he's good, I just tell him what I'm using the car for and he recommends me things and I just say yes.
  • Like 2
Broscience works, what tyres you on again?
Also add mk4 supra to swap list. People are starting to get them dialled up here with coilovers, tyres and brake pads they are quick.
Just Hankook RS-4 street tyres, I want to really feel the limits of the car and suspension before I put on better tyres.
Of course I also need to improve my driving. Being of Asian decent, my DNA has been programmed to drive Toyota Camrys, so trying to steer a stern drive is always a challenge lol.
  • Haha 3
1 hour ago, The Bogan said:
Politically incorrect, but funny, well..... . .
https://youtu.be/GvWXvw5HHDI
I can't believe how inappropriate TV was back then 😂
  • Like 1
To be fair, Drawn Together was extremely and deliberately inappropriate even for its time, worth a watch if you can find it. Wikipedia says 2004 which makes it younger than SAU
Getting ready to take out the shit box to SMSP, filled up 3x jerry cans and car has E20 or so in it at the moment.
Also noticed last time I was out there, during All Jap Day (useless day to try attempt PBs on the timed sessions, too many numpties in your race line) I tried to take T8 in 2nd and blazed the tyres, also because the throttle was a bit too sensitive so I've dumbed down the pedal to TB table. Should help make the TB less sensitive when I'm trying to negotiate a turn.
3 minutes ago, Duncan said:
Just go faster and use 3rd 😛
lol... or that!
Tonight I would say is my proper 3rd time out there, the last time I went out was with All Jap Day and both sessions didn't have a good crack at it.
Then when the track was clear and I was doing a good hot lap they ended the session early!!!!!!!
  • Like 2
Stiffer front springs did the trick, went 5s quicker and not to mention the track temps were quite low.
Had to retire the car early too, destroyed the rear pads. Had about 30 to 40% at the start of the night and by the end of 3rd session, it was down to the backing plate 😂
  • Like 11
And in car footage of the shit box, I believe I should be able to get it down into the flat 1m50s with more practice with these street tyres.
My lines are still a bit shit and I'm wasting a bit too much time coasting about finding the grip limits.
Once I can totally master the Hankook RS-4, I might move to a faster tyre like a Yokohama Advan A052.
  • Like 7
I get lectured all the time about this, one of my mates is a good steerer and a data boffin. He's always going on about 'zero time' and how I can't have the throttle shut and no brake input either. I've never driven SMSP but it looks like all the quick guys really test 'track limits'.
He's not wrong, because that time could be spent going faster! :D
SMSP is a fun track, it's also very scary. You always have the fear of binning the car with next to no run off!
Here's a lap with my mate driving the shit box, he hasn't driven it in about 5 years (since Wakefield days - had better tyres then, less power, however was lower and had softer springs).
  • Like 3
Are we watching the same video? You may not like Sandown or Broadford in Vic, that's for sure :D
Can you overlay his/your data with the Garmin to see where you are losing time?
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
